MAP Sensor Pin Diagram
Old Feb 18, 2005 | 07:26 AM
Grog's Avatar
So I bought a DTEC MAP sensor kit thinking that it would be compatible with either the UTEC or the Tuner Pro, but for some reason the connector is different. I'd like to rewire the connector for the 4-pin Molex connection on the Tuner Pro.
So my question is about the wiring. On the cable connector there are four pin slots and three wires. I'm guessing that the black is ground, red is +5V power, and the light blue is analog in, right?
And the other question is about the wiring pattern. If you were looking at the back of the UTEC or Tuner Pro, facing the female receptor on the Tuner unit, can someone give me the wiring pattern? Based on the Tuner Pro instructions I think it's
(Top of Tuner)
4 (black) 3 (open)
2 (lt blue) 1 (red)
but I want to make sure I'm interpreting the instructions correctly (it's unclear in the instructions whether you're facing the female receptor on the Tuner or the end of the plug). Thanks.
