Great $6.95 Shift Light
Old Mar 14, 2005 | 09:53 AM
BSREVOLUTION's Avatar
cool, thanks, ill grab my manual right now.
Old Mar 15, 2005 | 10:28 PM
bbbwrx's Avatar
Ordered one this weekend wish they had tracking or would actually tell me that they shipped my item.
Ben
Old Mar 16, 2005 | 04:42 AM
MalibuJack's Avatar
Originally Posted by Evoisdream
where did u find those lights from jack?
would you believe Pep boys? Their those ricer interior lights.. But they look like mini shift lights..
oh, and the load they draw is very low.. I have an Autometer shift light that draws more.... Just make sure that when you take those wires apart, that the resistor isn't in the adapter otherwise you'll have to remember to use a current limiting resistor to keep from burining out the LED.. basically on mine I took the cheesy LED's out and put in my own.
Old Mar 16, 2005 | 10:26 AM
Evoisdream's Avatar
i still dont really get where everything connects to but ill just look in my manual and try and figure it out from thier..
Old Mar 16, 2005 | 11:23 AM
EVIL MR's Avatar
up
Old Mar 16, 2005 | 03:02 PM
i hooked my led but it isn't working correctly. after the install, i turned the ignition on, the led lite up and then went off. i set the utec at 3000rpms for all three outputs, but nothing. for the install, i tapped the power wire for my tuner, and the ground was tapped in pin 9. did i do it correctly?
Old Mar 16, 2005 | 07:12 PM
nevermind, fixed it.
Old Mar 17, 2005 | 04:30 AM
EvoTech's Avatar
cool, how does it work?
Old Mar 17, 2005 | 08:52 AM
great, i thought it wasn't working correctly, but i went inside and came back out and it like a charm. very bright amber.
also, if anyone is interested in this light and have a map selector, all you need to do is tap one pin(9) and a 12v power.
Old Mar 17, 2005 | 09:20 AM
EvoTech's Avatar
Where did you mount it? I plan on recessing mine into the back of my panel when I get some time?
Old Mar 17, 2005 | 10:49 AM
im mounting mine right infront on the bezel around the speedo.
Old Mar 17, 2005 | 11:13 AM
Evoisdream's Avatar
did u go with the same on as he did the 6$ one?
Old Mar 17, 2005 | 12:15 PM
yeah. i just cant find screws small enough to mount the led, so i went to carquest and got some black mounting tape. i might leave it like that for now. ill try to get pics soon. justin
Old Mar 17, 2005 | 12:57 PM
EvoVIIIFL's Avatar
hey can anyone post pics or even perhaps a how to in the how to section???
Old Mar 17, 2005 | 02:12 PM
very easy. get the led, tap a 12v source. ground goes to pin 9 on the map selector plug. i just used a old connected and cut the pin out and used it.
