boost leak need help
Old Mar 9, 2005 | 03:10 PM
danny88m's Avatar
Question boost leak need help
I first installed a EBC and i wasnt able to control boost properly.it was either to high boost or to low.i uninstalled and installed a MBC. its been going up between 20-21psi and falls to about 12psi. I've checked hoses and piping doesnt seem to be leaking. i connected everything back to stock and boost stays between 10-12psi no more no less. i finaly came to the conclusion it might be the BOV gone bad. anybodies help will be appreciated thank you.
Old Apr 2, 2005 | 09:14 PM
UltraEvo77's Avatar
well atleast I'm not the only one with this problem!
if you havent already figured out!
the boost your running is only from the wastegate!
r u running the stock hose to BCS?
there is actually a restrictor (brass) on the turbo hose. than the T fitting (other side connected to wastegate) into the middle inlet on the BCS.
if your only running 10-12psi, your BCS is not getting the right reading which should go to your stock ECU.
well, thats pretty much what I know!
hope it helps!
Old Aug 21, 2007 | 05:01 PM
monsterevo6's Avatar
That Happen To Me, My Car Peak 26psi Leak Down To 17psi , After Lots Of Time On Shop, We Find Out That The Blowoff Was Opening On 18psi. Donīt Know Why Because I Change Stock And Buy Tomei Blowoff For The Same Reason.
Well I Hope You Find The Problem
Jef
Old Sep 8, 2007 | 12:59 PM
Camphasing's Avatar
yea BOV can do that
