Rich Fuel
Old Aug 5, 2007 | 11:38 PM
TKEVO's Avatar
Veteran: Air Force
Rich Fuel
I know Evos run rich straight from the factory but are you able to une them so they won't run rich or do they have to?
Old Aug 6, 2007 | 05:45 AM
tephra's Avatar
only their top end is rich!
you can do it with a little bit of effort you need, tactrix cable + wideband o2
Old Aug 6, 2007 | 09:46 AM
80210's Avatar
I would say that the high octane fuel map is rich. You can lean it out quite a bit, making sure you're safe by looking at knock sum.
Pick up a tactrix cable here: http://www.tactrix.com/product_info....844eb0170f297a
If you plan on doing a lot of tuning for accuracy, then go with a wideband. However, it is not necessary especially if your leaning out a stock map.
Like almost all cars, Evos don't have to run as rich as they come. You will see a huge difference by leaning out your mixture. Furthermore, you will most likely see an increase in MPG. Let me know if you have further questions or are looking for someone to lean out your map. I know some good tuners for this who can help you out while keeping costs at a minimum.
Old Aug 15, 2007 | 11:51 AM
Mellon Racing's Avatar
they are overly rich from the factory, leaning it out and advancing timing and boost can get you some pretty good gains if it's done right.
Old Aug 15, 2007 | 11:58 AM
TouringBubble's Avatar
Yup, they are VERY rich up top ...
http://www.frameleft.com/evo/gallery...selineDyno.jpg
That's my stock dyno. It drops in to the 9's just after 6500 RPM.
Old Aug 15, 2007 | 05:19 PM
TKEVO's Avatar
Veteran: Air Force
Aight well as long as I know I can tune it. I have a turbo xs to also help with that.
Old Aug 16, 2007 | 05:37 AM
turbo xs
Old Aug 19, 2007 | 01:17 PM
TKEVO's Avatar
Veteran: Air Force
yea the turbo xs utec came with the car. No reason to get rid of it.
Old Aug 19, 2007 | 01:41 PM
that's debatable
Old Sep 8, 2007 | 01:01 PM
Camphasing's Avatar
go get tuned...period...btw use the stock ecu to tune, with the taxtrix cable. no need to go beyond that.
Rich.B
May 13, 2013 05:21 PM
BoostinBird
May 6, 2010 06:41 PM
EnjoyDriving
16
Oct 30, 2008 10:52 AM
2fastevo
12
Sep 9, 2003 11:30 PM
OX
Apr 18, 2003 07:34 AM
