High Coolant Temp?
Old Aug 14, 2007 | 07:00 PM
kstpeter33's Avatar
High Coolant Temp?
I just got my tactrix cable and have been messing around doing some logs while driving around...
however i noticed that my coolant temp is rather high...well at least higher than some of the logs ive seen posted here on the forums (Ive seen 82 degrees)..
for instance, tonight driving home from work, the log starts with my coolant temp at 98.88 F
after driving about 15 minutes to my house the coolant temp had risen to 182.05 F
This is a stock ECU, mods are in my sig.....is this something to be worried about?
Old Aug 14, 2007 | 07:03 PM
moreryce's Avatar
sounds normal... i beleive we come with a 180 degree thermostat... so the thermostat wouldnt open until then.... your fine...
Old Aug 14, 2007 | 07:07 PM
kstpeter33's Avatar
alright thanks..wasnt sure since i just started logging myself..
was just a little worried because like i said i had seen some other logs posted with coolant temps as low as like 82
Old Aug 14, 2007 | 07:27 PM
TouringBubble's Avatar
What you are seeing is the difference of Celsius and Fahrenheit. 180*F is about 82*C.
Old Aug 14, 2007 | 07:32 PM
kstpeter33's Avatar
ah i thought it might have been that...
thanks again
Old Sep 8, 2007 | 01:03 PM
Camphasing's Avatar
thats normal.........
mrfred
Apr 9, 2014 05:45 PM
luizdiefenbach
Jul 25, 2011 12:15 AM
ScrappyJack
Dec 1, 2010 08:06 PM
lancebin
Mar 7, 2010 09:20 AM
ExViTermini
23
Sep 21, 2009 06:27 PM
