Zeitronix Wideband 02
Hey guys I got a problem with my Zeitronix system... currently have system set up only to boost sensor... car isn't turned over but boost reads 14.5-14.3.. I have checked the connections numerous times, checked power source, ground source.. everything! only thing i've noticed is that the brain box is RED HOT after only being on for just a few minutes... I'm gonna try checking the LCD against the laptop reading to see if its that.. but I REALLY doubt thats it... if any of you guys have had the same experience or solution could you please share??? thanks
I have the ground tied down to the same spot that I have by turbo timer grounded... now that I think about it... would that affect the readings that way? I have checked the other leads that are there and have them tied off so they don't touch anything else... I'm thinking i'll try a different ground and see what I get...
its suppose to only read gauge psi, i thought perhaps its using absolute pressure, but even when car is running and i engage launch control which hits 12psi.. still stays same: 14.3...
I'm going back and forth right now with "Ziggy" (guy from Zeitronix right?)
I have the red line coming off the ZT-2 spliced into another line that is connected to the cig lighter that is a true 12V line...
