Help With Afc Ii
Old Apr 3, 2005 | 01:22 PM
djmikeymike's Avatar
Question Help With Afc Ii
i just pick up a used afc II.......i hooked it up as per evotuners forum..........how do i intilize the unit back to factory sets.....
when i started may car the check engine light can one and my car idled @ 1500rpms.....and on the afc it was saying my rpms were at 500 rpms.
i set it to a 4cl and up to the right......low-throttle to 0 and high- throttle
5200 -3%
5800 -8%
6400 -10%
7000- 12%
7600 -14%
TH-point Low 25%
TH- point high 65%
please help
Old Apr 3, 2005 | 02:33 PM
changed pin 88 to 58.........car runs right now...........i set all high and low throttle to 0.......
i have a chech engine light
P0102 (MAF Circuit Low Input) what is this and how do i get it to go away?
Old Apr 3, 2005 | 02:40 PM
Kwman's Avatar
You have set it to Karmann sensor type right?
Old Apr 3, 2005 | 02:42 PM
no i don;t have any instructions........and i can't download them.....can you tell me how
Old Apr 3, 2005 | 05:25 PM
check engine light light went away
Old Apr 3, 2005 | 06:10 PM
joEvo8's Avatar
must of been that RPM wire hooked on the wrong pin.. i had the same problem.. someone need to update that thread on Evo tuners.. and Apex-i needs to update their Wiring Installation diagram.. they have the wrong ECU in the book..
Old Apr 3, 2005 | 11:36 PM
turbolarry's Avatar
I added the info in the article, thanks.
djmikeymike, don't make any correction adjustments to your AFC yet. If you need the manual, PM me your email address at evotuners so I can send it to you.
