jumpy pully pushy feeling???
Old Apr 13, 2005 | 09:05 PM
yellowman's Avatar
1) I mostly drive my car around the speed limit because of all of the cops around where I live, except for when I'm getting onto the interstate.
When I hold a steady speed, say... 40-45, the car gets a little jumpy. Is this being caused by too much/little fuel? I've tried playing around with my settings, but still get the same thing. I also set them to no correction and it still does it. Shouldn't 0% correction run the same as stock?
2) Why would the SAFC II throw a CEL? I just installed an 02 sensor extension to remove my CEL and it was working fine until I installed my SAFC. Any ideas???
Thanks
Old Apr 13, 2005 | 09:44 PM
Widebandphillip's Avatar
safcII shouldn't throw any cel codes if it was installed correctly. I see you have an mbc, did you remove your stock boost solenoid? That'll throw a light for sure.
Old Apr 13, 2005 | 09:48 PM
yellowman's Avatar
I don't have the MBC yet, so that can't be it. It was originally throwing the CEL because of the downpipe and hi flow cat. I thought I had fixed that with the extended o2 sensor, but maybe not. hmmmm
As far as install, should be ok.
Old Apr 13, 2005 | 11:22 PM
turbolarry's Avatar
As long as your on stock injectors, leave it at 0%. What does the code say?
Old Apr 22, 2005 | 06:54 PM
cyberninja's Avatar
I know that my car is doing the same exact jerking execpt the SES light. With everything set a 0% and the low and high throttle set at the same, I'm still getting the same thing. I ran WOT once and pulled all the way into third gear and my car back-fired. I held the accelerator in without moving it at all and the car felt like it was going to die. My cyl. is set at 4 as needed and sensor type is set at karman, so I don't know what is going on. I just disconnected the S-AFC 2 just in case. Can someone please respond. My mods are 3" turboback with cat delete, intake, and grounding wires. Can someone please help me.
Old May 4, 2005 | 11:52 AM
bdking57's Avatar
mine has a slight pushy and pully feeling that i notice when im slowly accelerating. I can notice this starts at a very low rpm and feels sorta funny.. no backfires or anything though. Check your spark plugs.
Old May 4, 2005 | 05:30 PM
blueo4's Avatar
is it set at 4 cyl with the arrow pointing upward to the right! I would suggest initializing the thing and go from there! make sure you are using pin 58-if you installed it yourself u know what i am talking aout because some people have it incorrect!
Old May 4, 2005 | 07:03 PM
bdking57's Avatar
mine is doing this too.. i think it might because it wasnt solder but the clips were used. is anyone else not solder and getting this?
Old May 20, 2005 | 12:24 PM
bigjhoney's Avatar
Got the same thing, except I got a patch harness. Thought it was not enough fuel, richened it up a bit and still...
Old May 22, 2005 | 07:58 AM
bigjhoney's Avatar
What are your spark plug gaps to everyone who has this problem?
Old May 23, 2005 | 04:15 PM
bigjhoney's Avatar
Well just to update, I put some miles on my car and seems like the computer had to relearn the new settings, feels better now.
Old May 23, 2005 | 07:37 PM
EVOLUTIONIZE's Avatar
I had to set mine up for 2 cyl, in 4 cyl my rpms are waaaayyy off, in 2 cyl the problem got fixed now im off by maybe 100 200 rpms. Ive found ppl with the same problem and having to move it down to 2 cyl..
Old May 23, 2005 | 07:44 PM
RogueSTi's Avatar
Jumpy pushy pully feeling? Sounds like Cocaine...Drugs are bad!!
Old May 23, 2005 | 07:46 PM
It does have a funny subject, lol but we get the point
Jerky feeling?
Old May 28, 2005 | 10:21 PM
yellowman's Avatar
Would I be better off selling the SAFC and getting a reflash?
