jumpy pully pushy feeling???
Old May 28, 2005 | 10:30 PM
badhabit90's Avatar
Cool
if you keep the SAFC-II keep a bottle of excedrin migrane medicine handy....especially if you dont know how to tune it. if you get a reflash...send in your ECU and a list of mods, get it back, install it, sit back, relax, and enjoy your new power without tuning headaches. chose your tuner wisely...young grasshoppah....
Old May 30, 2005 | 05:04 PM
bigjhoney's Avatar
Changed my intake and havent had an issue yet.
Old Jun 15, 2005 | 11:17 AM
cpdevo31's Avatar
Originally Posted by cyberninja
I know that my car is doing the same exact jerking execpt the SES light. With everything set a 0% and the low and high throttle set at the same, I'm still getting the same thing. I ran WOT once and pulled all the way into third gear and my car back-fired. I held the accelerator in without moving it at all and the car felt like it was going to die. My cyl. is set at 4 as needed and sensor type is set at karman, so I don't know what is going on. I just disconnected the S-AFC 2 just in case. Can someone please respond. My mods are 3" turboback with cat delete, intake, and grounding wires. Can someone please help me.
does it do it often? i have leaned my car out alot, and was playing around with it one night setting everything back to 0%. got on it the first time and backfired bad the same way u did. if he keeps happening lower you hi throttle from 4400rpm to 7200rpm, anwhere from -2% to -7%. that might help it not backfire till you can find someone who knows exactly what they are doing.
Old Jul 23, 2005 | 04:47 AM
WongFu's Avatar
What you have to do is mess with your boost contorler. i was having the same problem when i was on the gas it goes away cause of wot
