just tuned question?
Old Apr 30, 2005 | 04:35 PM
  #31
MalibuJack's Avatar
Originally Posted by Evoisdream
ok here it is u can c i start it and it dies and do it again and then on the third one i revved it a tiny bit ...
also i should be gettting a wideband here soon which will give my a/f but honestly if the car would stop doing this i would rather have it rich so any adjustment would b nice
Wow, your idle MAF readings are WAY high.. At least if the ECU is seeing that number.. Try removing in the 0% column in your fuel map, 0-950 rpm cells, remove about 30% fuel, then 1000, 25% 1250, 15% 1500, 15% 1750, 5%
Hope that makes sense to you.. You should be telling the stock ECU that at idle, its running about 30hz, in reality, you should be looking only at your fuel trims with an OBD-II scanner, and adjusting accordingly.. Maybe this will help.
Old Apr 30, 2005 | 04:36 PM
  #32
MalibuJack's Avatar
Wow, Basically I suggested scaling your injectors at idle, but it looks like they did it with the global scaling.. Glad everything is fixed..
Old Apr 30, 2005 | 05:46 PM
  #33
Widebandphillip's Avatar
i hope you didn't pay your tuner too much since he only basically adjusted the a/f.
Old Apr 30, 2005 | 05:52 PM
  #34
Evoisdream's Avatar
yeah it wasnt much at all it was a full dyno and did all the a/f and scaled the injectors so it works good thanks again for the help
Old Apr 30, 2005 | 06:17 PM
  #35
Didn't really need the dyno to tune a/f but in your case you didn't have a wideband so i guess so.
Old Apr 30, 2005 | 06:25 PM
  #36
RAWMR's Avatar
There is a book called"Comperition Car Datta Logging - A Practical Handbook" by Simon McBeth. It is published by Haynes Publishing. ISBN 1 85960 653 9. I just got it at Barnes & Noble so I have'nt read much but, so far, it seems pretty informative.
Good luck with your problem,
RAW
Old Apr 30, 2005 | 06:31 PM
  #37
Evoisdream's Avatar
Really? does it cover air to fuel timing etc?
Old Apr 30, 2005 | 07:04 PM
  #38
MalibuJack's Avatar
Tuning is partly about understanding your particular car and engine.. So any generic book should give you good guidelines and techniques, but be aware that every car is different and has different requirements and of course needs and quirks... Tuning my Malibu's V8 and Tuning the Evo are as different as you can get, but the principles are exactly the same when it comes to how timing works and air fuel ratios.. But the amount of timing or fuel for the two are completely different.
Old Apr 30, 2005 | 07:15 PM
  #39
Evoisdream's Avatar
yeah i figured that much... im kinda in the point where i understand it somewhat but u wouldnt know what area of a/f to even look for and how much should b under certin loads etc...
Old Apr 30, 2005 | 07:27 PM
  #40
MalibuJack's Avatar
Yeah, that takes awhile to grasp, I learned most of it by logging lots of data from my car with different maps running, and logging the MAP-0 (stock setting) for weeks when My car was stock enough to run okay without a map running.. The more I understood about what it was doing stock, the more prepared I was to make improvements, also understanding what felt good, and what felt bad, and good/bad noises.. I find I am very frequently listening to the Tuner-Pro's headphones (knock sensor) All I really hear is the valvetrain, but detonation is something you can hear over it...
Old Apr 30, 2005 | 07:30 PM
  #41
Evoisdream's Avatar
yeah thats awsome i dont want to become like a Pro tuner or anything lol i just would like to be able to watch for knock and correct it if i c it and if i add something small say a fmic or something to adjust a few things to get the extra power out of it or make it run smoothly again...... thanks for all the help jack
