just tuned question?
hey guys i just got to the dyno yesterday and tunned and everything went awsome.. i made 356/355 on 91 oct and 21 psi.. drove yesterday and it was all perfect.. well the car sat overnight and when i went to start it this morning it was very sluggish and bogged and woud die.. so instead of warming it up cause it would just die i tried ti kep it in high rpm and once it got a tiny bit warm it would idle and didnt die.....
and once its fully warm the car runs amazing is thier a ignition startup i need to adjust or someone have an idea on anything else?
Thanks
evoisdream
datalog about 5 posts down
Thanks
evoisdream
no i just got the serial to usb adaptor so i can put my laptop in the car ill get some logs and post so u guys can help!
its weird the idle is more then fine after its warm but in the morn i cant even get the car to like run right at all....
ummm here is my best shot at logging im new so i still dont know all the tricks help me plz
hehehe
im pretty sure my idle needs to be raised becuase it was only at like 700-800 how would i do that?
heheheim pretty sure my idle needs to be raised becuase it was only at like 700-800 how would i do that?
mine did the same thing the morning after it was tuned. also, who tuned it and how reputable are they? anyway, the weird idle and sluggish start-up is also just part of the highly tuned vehicle you own.
yeah i know the idle will b weird and what not but it was terrible like i had to struggle to keep it running
they are pretty reputable awd dyno been around for a long time and have done a ton of utec's im sure they are not #1 or anything but i mean i made really good power and it runs amazing once its warmed up....
Sounds like a cold start issue, maybe a fuel enrichment table/warm up table adjustment? Should be fixable. Maybe a start up crank setting?
Check with malibujack he seems to help out others with issues on the utec.
yeah thats all im seeing 2 im a little confused i made the 356/355 so i think so lol the car barley ran b4 i got thier and now it runs amazing just doesnt when its cold
