look at this log, ok?
Old May 6, 2005 | 06:03 PM
SOUTHSIDEITALIA's Avatar
5/6/05-18:25:26 - Obd2
Time,RPM,Timing,TPS,O2 1 Bank 1,O2 Trim 1 Bank 1
19:29.31,906.0,11.0,0.0,0.48,2.34
19:29.55,906.0,9.0,0.0,0.44,2.34
19:29.78,906.0,8.0,0.0,0.42,3.13
19:30.00,926.0,8.0,0.0,0.28,3.13
19:30.22,1227.0,15.0,0.0,0.82,3.91
19:30.45,1438.0,17.0,0.0,0.86,3.13
19:30.68,1348.0,16.0,5.11,0.02,3.13
19:30.91,1391.0,16.0,10.22,0.02,3.91
19:31.14,1402.0,29.0,15.32,0.8,4.69
19:31.35,1602.0,30.0,22.79,0.8,3.91
19:31.58,1844.0,28.0,27.9,0.62,2.34
19:31.81,2031.0,24.0,34.97,0.5,0.78
19:32.05,2328.0,23.0,40.86,0.72,-0.78
19:32.28,2660.0,20.0,44.4,0.74,-2.34
19:32.51,2945.0,16.0,47.15,0.76,-4.69
19:32.72,3324.0,12.0,55.01,0.44,0.0
19:32.95,3711.0,10.0,83.3,0.88,0.0
19:33.18,4258.0,11.0,99.41,0.86,0.0
19:33.41,4918.0,7.0,99.41,0.88,0.0
19:33.64,5609.0,9.0,99.41,0.88,0.0
19:33.88,6262.0,12.0,99.41,0.88,0.0
19:34.09,6824.0,14.0,99.41,0.88,0.0
19:34.32,7539.0,16.0,99.41,0.9,0.0
19:34.56,6887.0,34.0,12.18,0.76,0.0
19:34.79,4840.0,38.0,99.41,0.64,0.0
19:35.01,5328.0,11.0,99.41,0.92,0.0
19:35.23,5691.0,8.0,99.41,0.92,0.0
19:35.46,6016.0,12.0,99.41,0.9,0.0
19:35.68,6297.0,13.0,99.41,0.9,0.0
19:35.92,6578.0,15.0,99.41,0.9,0.0
19:36.14,6863.0,17.0,99.41,0.9,0.0
19:36.36,7266.0,17.0,99.41,0.92,0.0
19:36.59,6879.0,29.0,10.61,0.16,0.0
19:36.82,4777.0,29.0,99.41,0.9,0.0
19:37.05,5422.0,5.0,99.41,0.92,0.0
19:37.28,5652.0,12.0,99.41,0.9,0.0
19:37.51,5770.0,12.0,99.41,0.92,0.0
19:37.72,5930.0,13.0,99.41,0.92,0.0
19:37.95,6078.0,14.0,99.41,0.9,0.0
19:38.18,6238.0,15.0,99.41,0.92,0.0
19:38.41,6371.0,16.0,99.41,0.92,0.0
19:38.64,6531.0,14.0,99.41,0.92,0.0
19:38.86,6680.0,15.0,99.41,0.92,0.0
19:39.09,6813.0,15.0,99.41,0.92,0.0
19:39.31,6938.0,15.0,99.41,0.92,0.0
19:39.55,7652.0,17.0,99.41,0.92,0.0
19:39.77,7262.0,30.0,16.5,0.02,0.0
19:40.00,6563.0,35.0,3.93,0.34,0.0
19:40.22,4734.0,38.0,0.79,0.34,0.0
Old May 8, 2005 | 03:30 PM
nothere's Avatar
what ems are you using? tell us what you are all about.
Old May 8, 2005 | 05:39 PM
I just have the TT flash, but was curious if the timing pull may be a sign of detonation? 21 lbs of boost
I logged with the pocketlogger
Old May 8, 2005 | 06:05 PM
nothere's Avatar
it could be, look where the timing is afterwards, it was 29 and then 12. maybe you should cut the timing back from 29 to something closer to 12 by the time you hit 5200rpm.
I have a different condition than you but I noticed a knock* at 5400 rpm just today. I have been leaning out my fuel because I have water injection. Needless to say I put some fuel back in in that area. And held the timing back there too.
* I saw a timing retard because of knock
Old May 8, 2005 | 06:45 PM
Jorge T's Avatar
that looks like an shift point to me....
Old May 8, 2005 | 06:47 PM
nothere's Avatar
I thought the same thing except the tps is at 99
