Which Inputs Would you guys prefer?
Old May 7, 2005 | 09:34 AM
Stormtrooper's Avatar
Hi everyone, I'm helping a friend do a little research for a project he's working on.
Besides knock which speed readings would you guys prefer to datalog/read most from the ECU? Which analog readings would you guys prefer to read from the ECU?
Personally, I would prefer in order of priority:
Speed:
1. RPM
2. Injector Duty Cycle
3. MPH
Analog:
1. Air Intake Temperature
2. TPS
3. MAF
4. Engine coolant temp
Any others from the ECU you would care to read in and datalog?
Old May 7, 2005 | 09:55 AM
Steven's Avatar
1. LTFTs
2. Airflow gal/min
3. Boost Estimate
Old May 10, 2005 | 08:42 AM
thx steven....
anyone else?
Old May 10, 2005 | 09:17 AM
MalibuJack's Avatar
Front O2 voltage (for as un-useful as it is)
Ignition timing
Short term fuel trims (I saw long term, but short term gives you an indication of how correctly the car is idling)
clutch switch, a/c cycling, basically the switched inputs or outputs for items
Old May 12, 2005 | 01:02 AM
Ignition timing
Thanks Malibu.... I should have just PMed you about this personally =P
