Whats the difference between these to?
Old May 11, 2005 | 06:22 AM
Junkboxer's Avatar
whats the difference between these two boost controlers? do i need both of them to control my boost levels or can you just use one of these? im confused because one is like electonic, and the other goes right into the engine bay. sorry for the newb question but im new toforced induction. here are the name and links:
-Turbosmart manual boost controller - http://www.buschurracing.com/cgi-bin....cgi?27X376545 (last item on the page)
-HKS EVC 5 boost controller - http://shop.store.yahoo.com/titanmot...sevc5boco.html
**if only one is needed, what is reccommended? i would think the electronic one has more options but i dont really know.
Old May 11, 2005 | 04:16 PM
RallySport Direct's Avatar
Silver Sponsor
Yes the turbosmart is a Manual and the HKS is a electronic. It really depends on what you are doing what one you would recommend.
Almost any good quality manual boost controller is going to be able the same. You wil lwant to make your decision based on what you are going to be doing to the car.
Are you just going to set the boot and forget about it?
Are you going to turn the boost up and use race gas?
There are many things to decide when selecting boost control let me know what you are going to do with the car and I can try and help you decide.
Ben
Old May 11, 2005 | 04:56 PM
Junkboxer's Avatar
well i wont be using race gas. but can i still up the boost if i wanna race (this will be very rare btw). id like to be able to set it and forget it but if i get nmore mods wont i have to tune it or change it?
Old May 12, 2005 | 10:09 AM
Silver Sponsor
Really the only advantage A EBC has over a MBC is that you can change it inside that car. And it can read boost and adjust itself to what the boost is doing. But if you are only going to change it a couple times a MBC is very easy to tune. All you do it turn a adjustment screw to change the boost setting. I would recommend a MBC for your situation and also make sure you don't crank the boost to high.
Ben
Old May 12, 2005 | 10:17 AM
Junkboxer's Avatar
Ben
exactly...how will i know when im boosting it to much. and having it adjust according to boost levels is somehting you would want, wouldnt you?
Old May 12, 2005 | 11:59 AM
Silver Sponsor
You NEED a boost gauge. I would not go above 20 psi to be safe.
ben
