Bung location
Old May 12, 2005 | 08:55 AM
nirvevo's Avatar
Bung location
I'm planning out bung installs for a (Tuner w/ Bosch) wide band 0s sensor AND a bung for an EGT sensor.
How about some informed opinions on the best locations for both. When referring to side locations please use driver or passenger side to describe which one you are referring to. (American Drive of course)
Any help greatly appreciated
Dean
Old May 12, 2005 | 10:27 AM
Evoisdream's Avatar
i beleave with the a/f one wideband u want like downpipe area....
and egt u want in the manifold for sure i just did mine the other day.
Old May 12, 2005 | 11:19 AM
MalibuJack's Avatar
Thats pretty correct.. you want the O2 sensor in the downpipe, Mine is about 6-8" from the elbow of the downpipe near the oil pan.. Some people put it further back since the slightly cooler temperature may let it live longer. The EGT bung, you can put it after the turbo, or before.. The best place to put it is in the #1 or #2 runner of your exhaust manifold, I would generally recommend putting it in the runner furthest from the fuel rail's feed from the fuel system since if your going to have a lean condition and high EGT's, it'll usually be seen the furthest from the fuel feed first.
Old May 12, 2005 | 11:42 AM
Evoisdream's Avatar
i put my egt in the 1st runner thier is a big thread about this is u search
Old May 12, 2005 | 11:50 AM
EVOla_VIRUS's Avatar
My EGT went in cyl 2.....if you have a test pipe, can you temporarily place the o2 where the second o2 sensor goes?
Old May 12, 2005 | 01:49 PM
sgplancer's Avatar
You can, but the further away from the turbo you go, the chance you could get leaner readings, and the O2 sensor errors for heat range issues.
I installed mine in basically the same location as Jack, but just a tad closer to the flange that joins the d/p and t/p or cat.
