Zeroing out the Emanage?
Old May 12, 2005 | 02:48 PM
vegeta irie's Avatar
Sorry for the newb question. I wanna get a reflash. (Heard I could get more power out of a reflash than the Emanage ). I was told that the best thing to do was zero out the Emanage, so how do U do it?
P.S. How hard is it to take out?? Do U have to remove the solder or just remove the wires from the ECU?
TIA,
Josh
Old May 27, 2005 | 11:47 AM
992gnt's Avatar
To get zero values into the emanage, just open the Support software and click on export data. Since you haven't opened any files, you will essentially load blank fuel and timing maps.
As for un-installing it, it depends on how it was installed. If the harness was tapped into directly, you'll want to un-solder and tape everything back up. The MAF signal wire will need to be spliced back together as well. If a harness was used, just unplug it.
Old May 27, 2005 | 03:19 PM
cool thanks for the help
Old Aug 1, 2005 | 09:29 PM
theace's Avatar
yeah thanks for the help...
