More tuning woes
Old Jun 3, 2005 | 10:43 AM
dryad001's Avatar
More tuning woes
Since last night when I put in the new plugs the car ran great on the initail run. Now, thankfully I was logging at the time and when I was nearing redling the car felt like it hit a brick wall, I wasn't expecting that and hurt my neck a little bit. Here is the log.
3095 -11.6 319 28 00 00 +25.5 14.0 ECU. +16.2 ECU. 373 14.05
3097 -8.8 344 30 00 00 +21.3 15.6 ECU. +16.2 ECU. 423 14.15
3192 -5.5 388 31 00 00 +19.7 17.4 ECU. +17.0 ECU. 448 13.78
3320 -2.3 439 33 00 00 +17.5 21.2 ECU. +17.5 ECU. 530 12.71
3475 -0.6 500 35 10 00 +15.6 23.2 +12.8 +17.5 ECU. 631 12.14
3607 +0.6 656 43 10 00 +10.7 31.2 +12.8 +17.5 ECU. 744 11.98
3796 +2.8 837 64 10 00 +6.6 43.8 +12.6 +17.5 ECU. 1012 11.77
4016 +5.7 1066 96 10 00 +2.9 58.0 +13.1 +17.5 ECU. 1179 11.52
4268 +10.2 1326 100 30 00 -0.8 75.0 +10.2 +17.5 ECU. 1633 11.12
4597 +15.1 1312 100 40 00 -1.7 76.6 +8.5 +17.5 ECU. 1644 10.62
4873 +18.6 1381 100 50 00 +0.4 81.7 +7.3 +17.5 ECU. 1677 10.52
5192 +21.0 1470 100 60 00 +0.3 85.9 +8.0 +17.5 ECU. 1572 10.68
5455 +21.2 1519 100 70 00 +0.3 88.7 +8.3 +17.5 ECU. 1811 10.64
6230 +19.8 1700 100 70 00 +7.4 96.2 +14.2 +17.5 ECU. 2100 12.45
4721 +14.9 90 2 00 00 +34.9 8.3 ECU. +17.5 ECU. 127 13.17
4301 +6.5 75 0 00 00 +35.9 6.8 ECU. +17.5 ECU. 183 12.42
3940 -2.0 84 0 00 00 +37.9 8.2 ECU. +17.5 ECU. 109 13.42
3611 -9.8 77 0 00 00 +46.0 5.2 ECU. +17.5 ECU. 90 13.75
3353 -13.9 70 0 00 00 +27.9 5.2 ECU. +17.5 ECU. 85 14.30
At 6230 it went way lean, this is the modified version from last time and still had to add a little more fuel but the injectors are prety much maxed out. The MAP is very very close to my boost gauge. Also I noticed the MAF MOD hit 2100, I know that there is a way to change that, to raise the maximum allowed MOD, right? There rugular ecu timing threw me a little and didn't know if it was right or not just by looking at 4016-4873. Before I hit the "wall" the car ran great, pulled really hard and no knocking. If you want more info please ask, and I will tell.
Old Jun 3, 2005 | 11:16 AM
EvoTech's Avatar
You hit fuel cut. No doubt. You need to raise your Max MAF to something higher.
Old Jun 3, 2005 | 11:32 AM
dryad001's Avatar
Same thing I was thinking but wasn't too sure. I don't really want to screw with any of the settings until I understand what they do. Some of them are pretty easy though.
