Map sensor installed
Old Jun 29, 2005 | 09:39 AM
SwiftEVO's Avatar
I keep seeing everyone talking about keeping the vac line as short as possible and the wires too. Why is that? Is it just to keep the calibration numbers in the utec close to correct? Or does it actually affect the map sensor?
I will be hooking up my alky kit soon and will be using my map sensor for the utec for the progressive controller on the kit. Will it have to calibrated too? If not then Why does the utec have to be calibrated?
--Josh
Old Jun 29, 2005 | 09:46 AM
BJai02's Avatar
--Josh
Keeping teh vac line as short as possible so the default calibration that TurboXS has is very close to the true reading. But anyhow, you should calibrate the MAP sensor in your UTEC so you know you are getting a good reading.
Old Jun 29, 2005 | 10:28 AM
MalibuJack's Avatar
Its for several reasons.. the first easy answer is the UTEC comes with calibration values for a typical GM sensor install, so if you want the values to be close (in my case it actually was almost perfect) you keep the lengths of wire as short as possible to reduce signal loss, since its an analog signal, poor connections and long wires and even unshielded radio noise could affect the reading. The short hoses gives you the most accurate measurement since some vacuum lines will swell under boost and may show slightly lower pressure because of it. (at least it could be enough difference to affect the accuracy of the gauge)
Old Jun 30, 2005 | 09:44 AM
SwiftEVO's Avatar
I figured thats all it was for but I just had to be sure. Thanks for the help.
--Josh
BSREVOLUTION
Feb 23, 2005 05:37 PM
superman105
25
Feb 10, 2005 07:37 PM
VTECH8TR
Jan 20, 2005 08:49 AM
LEVIII
Sep 15, 2004 08:46 AM
bishiboy
Aug 11, 2004 02:14 PM
