Sorry if this is a stupid ??
I just got my Utec in the mail today, and my question = If I hook it up does the MAP that it is set on different than stock? Or is it tweaked a little bit? Thanks for any replies
It is base map from TurboXS, which is NOT the same as your stock ECU. That's why you need to install UTEC at Map0, run and log a lot of data with it. Then build an ignition map base on what your ECU wants to run. And you will need to adjust the AFR accordingly with a wideband O2 sensor.
