went tuning for 3 hours...heres what i did...
Yep, I agree with Gestalt, Thats kinda what I was eluding to in an earlier post.. Look at your boost/torque curve, your getting real rich, real fast, but your running alot of timing at that point, I think running a bit leaner with a little less timing will help you out alot.
Not much to elaborate on, but the more efficient burn (leaner) will produce more exhaust volume, a little less timing will also mean you can get more expanding gases into the exhaust, and that will help your spool..
well, here is the latest. I hooked up my boost leak detector and injected 25 psi. There were 2 small leaks. Tightened one clamp and the other was in the throttle body shaft. Its small, but i think its there for good. Also preloaded the WG actuator a few turns. I didnt get anywhere. This car has 272/272, tubular header, 3" exhause everything. It should be flowing like crazy. Ime sure i usewd to get 20 psi at 37-3800 rpm. The turbl spins freely. I turned off the UTEC and went back to my flash. Talk about playing "stump the tuner" ime down to a pluged 3" racing cat.... Ill put the test pipe on soon and if that isnt it......might buy another turbo....
Thanks for u-guyses help......... ray
Code:
Load Knock Mod Mod Mod WB
RPM MAP MAF TPS Site Count Ign#1 Inj#1 Ign Fuel Boost MAF AFR
psia Hz % deg duty deg % (OL) Hz
2244 -7.2 269 100 0 0 25.3 13.3 ECU. 0 ECU. 251 14.33
2214 -4.9 265 100 10 0 24.5 9.9 ECU. 0 ECU. 250 13.97
2250 -2.8 238 100 10 0 23.3 9.9 ECU. 0 ECU. 226 12.46
2256 -0.4 293 100 10 0 21.3 9.6 ECU. 0 ECU. 321 12.42
2354 1 277 100 10 0 20.5 11.4 ECU. 0 ECU. 252 13.81
2454 1.4 293 100 10 0 19.4 11.5 ECU. 0 ECU. 286 14.18
2511 1.9 341 100 10 0 20.5 13.3 ECU. 0 ECU. 365 14.42
2583 2.4 380 100 10 0 21.3 14.5 ECU. 0 ECU. 352 14.49
2675 2.9 386 100 10 0 19.6 15.6 ECU. 0 ECU. 429 14.18
2763 3.5 396 100 10 0 19.2 18.9 ECU. 0 ECU. 519 13.72
2815 4.2 437 100 10 0 19.2 21.5 ECU. 0 ECU. 434 13.12
2939 4.9 490 100 10 0 17.1 22.7 ECU. 0 ECU. 561 12.52
3013 5.5 536 100 10 0 16.4 23.7 ECU. 0 ECU. 658 12
3115 6.6 599 100 10 0 14.7 28.6 ECU. 0 ECU. 534 11.87
3233 7.5 838 100 10 0 12.5 34.5 ECU. 0 ECU. 786 11.81
3360 8.7 909 100 10 0 10.5 37.6 ECU. 0 ECU. 1018 11.68
3486 10.4 749 100 10 0 8.5 45 ECU. 0 ECU. 1182 11.61
3642 12.5 899 100 20 0 8.2 56.7 ECU. 0 ECU. 1295 11.53
3835 15.1 1179 100 40 0 8.2 62.1 ECU. 0 ECU. 1282 11.45
4011 17.7 1470 100 60 0 8.2 67.2 ECU. 0 ECU. 1577 11.34
4208 20 1066 100 70 0 8.6 69.2 ECU. 0 ECU. 1128 11.27
4374 21.4 1400 100 70 0 8.6 67.1 ECU. 0 ECU. 1362 11.3
4547 21.7 1400 100 70 0 8.6 71.1 ECU. 0 ECU. 1412 11.42
4721 21.6 1577 100 70 0 8.6 72.5 ECU. 0 ECU. 1424 11.49
4945 21.2 1483 100 70 0 10 78.3 ECU. 0 ECU. 1689 11.45
5151 21.4 1683 100 80 0 11.2 81.8 ECU. 0 ECU. 1577 11.34
5291 21.7 1587 100 80 0 11 79.7 ECU. 0 ECU. 1543 11.24
5464 21.9 1612 100 80 0 12.1 83.7 ECU. 0 ECU. 1577 11.24
5640 21.9 1718 100 90 0 12.2 84.2 ECU. 0 ECU. 1730 11.28
5827 21.2 1754 100 90 0 13.3 84.1 ECU. 0 ECU. 1730 11.3
5973 20.9 1618 100 90 0 13.2 86.4 ECU. 0 ECU. 1779 11.27
6127 20.2 1805 100 100 0 13.5 85.5 ECU. 0 ECU. 1779 11.24
6289 20.2 1754 100 100 0 14.3 85.3 ECU. 0 ECU. 1831 11.23
6435 20.5 1937 100 100 0 15.7 88.2 ECU. 0 ECU. 1824 11.33
6561 20.2 1689 100 100 0 15.8 87.7 ECU. 0 ECU. 1858 11.45
6706 20.3 1831 100 100 0 16.3 88.8 ECU. 0 ECU. 1865 11.49
6830 19.8 1824 100 100 0 16.3 90 ECU. 0 ECU. 1851 11.56
6988 19.5 1879 100 100 0 18.4 88.7 ECU. 0 ECU. 1893 11.61
7107 19.3 1865 100 100 0 18.5 93 ECU. 0 ECU. 1879 11.67
wow ray...im pretty damn stumped as well. thats weird how slow your boost comes on. i have the 272's now as you already know, my boost does come on later for sure, but i believe it hits full boost at and around 4k, no later. we have a very similar setup, yet you have parts that should make your flow rate better than mine. i dont know, but i do have a solution for you! ill be coming out to tucson like the second week of september. along with a friend of mine who will definitely beable to help out your situation, guaranteed. let me know if you still want in on that. Also I do know for the that a AEM EMS would help you out!
Best mod ive done to my car other than cams of course. if not that doesnt matter though, because he can do u-tec as well.
ya know.. check the vacuum line to the BOV.. I wonder if its not getting adequate pressure to stay closed, or its partially open for some reason.. The Cams will slow down your spool a little.. But if your seeing it delayed that much, I wonder if maybe something is restricting or bleeding off pressure to the BOV preventing it from staying completely closed..
Well, seems like the boost now comes on a couple hundreds RPM earlier. I see that your ECU still wants to run some very advanced timing during the spool, you might as well try to run it a little leaner too. Just watch out for the knock counts... I runs 91 octane and tuned at 21 psi, but I have no problem having the AFR curve not to hit 11.8 to 12.0 untill 4000 RPM, then gradually enrich to 10.8 by 6000 RPM (to fight knocks), and lean it out a bit back to 11.1:1 by 7000 RPM.
MJ, when i was boost leak testing, the BOV would lift right at 25 psi. So i dialed in a few more turnes and got it to hold the static 25 psi. Maybe i need to go back to the 9.8 hotside....did you get the 20g yet???? I might get one also. If not that one, the 3071....Ray
dont know about the actuator. I know it holds pretty tight. I had to give it a little air in order to loosen it up enough to slide off the arm. I might put the 9.8 hotside back on....
Well to help you out a little bit i went out and did a log in 3rd gear, on ramp are only so long here. This is done on the MPS UTEC logger so the AFR's are next to the knock column but everything looks like it's in the right place.
2583, -9.6, 285, 78, 10, 00, 13.6, 11.8,+10.3, -5.0,ECU. , 288
2730, -6.2, 328,100, 10, 00, 11.7, 13.8,+10.0, -5.0,ECU. , 459
2815, -2.7, 380,100, 10, 00, 11.5, 13.9, +9.6, -5.3,ECU. , 353
2822, +1.2, 423,100, 10, 00, 11.4, 15.7, +9.3, -6.1,ECU. , 314
2871, +2.4, 460,100, 10, 00, 11.5, 17.7, +9.0, -6.8,ECU. , 347
2955, +3.6, 537,100, 10, 00, 11.3, 20.5, +7.9, -7.5,ECU. , 611
3046, +5.3, 580,100, 10, 00, 11.3, 22.3, +6.9, -8.8,ECU. , 541
3138, +6.7, 676,100, 10, 00, 11.7, 23.3, +6.1, -9.5,ECU. , 679
3284, +8.7, 776,100, 10, 00, 11.3, 31.1, +5.1,-10.9,ECU. , 710
3394,+10.8, 888,100, 10, 00, 11.1, 35.2, +5.0,-12.1,ECU. , 737
3534,+13.4,1048,100, 20, 00, 10.8, 42.0, +4.8,-13.7,ECU. , 741
3695,+16.7,1152,100, 30, 00, 10.8, 47.8, +4.9,-16.7,ECU. , 654
3853,+19.8,1113,100, 30, 00, 10.7, 44.9, +5.3,-19.0,ECU. , 776
3977,+22.6,1154,100, 40, 00, 11.0, 46.6, +5.7,-20.9,ECU. ,1041
4166,+24.4,1272,100, 40, 00, 11.4, 47.8, +6.1,-22.1,ECU. , 980
4368,+25.5,1219,100, 40, 00, 11.5, 49.1, +6.7,-22.5,ECU. ,1072
4504,+25.3,1385,100, 40, 00, 11.6, 48.4, +7.3,-22.8,ECU. , 996
4668,+25.1,1344,100, 50, 00, 11.7, 50.8, +7.3,-22.8,ECU. ,1131
4880,+24.9,1377,100, 50, 00, 11.6, 52.5, +7.4,-23.2,ECU. ,1162
5020,+24.2,1543,100, 50, 00, 11.5, 58.3, +7.5,-24.0,ECU. ,1126
5192,+24.2,1488,100, 60, 00, 11.3, 59.3, +7.7,-23.4,ECU. ,1250
5341,+24.2,1644,100, 60, 00, 11.3, 60.2, +8.4,-24.1,ECU. ,1282
5546,+23.8,1628,100, 60, 00, 11.1, 58.3, +9.6,-25.1,ECU. ,1146
5698,+23.8,1650,100, 70, 00, 11.3, 65.1,+10.2,-26.9,ECU. ,1336
5889,+23.6,1742,100, 70, 00, 11.3, 67.7,+12.0,-27.0,ECU. ,1237
6027,+23.4,1779,100, 70, 00, 11.2, 66.3,+13.8,-27.0,ECU. ,1173
6172,+23.2,1792,100, 70, 00, 11.1, 65.9,+15.2,-27.5,ECU. ,1366
6361,+23.2,1811,100, 70, 00, 11.1, 69.6,+16.3,-27.8,ECU. ,1336
6510,+23.0,1845,100, 80, 00, 11.0, 68.0,+17.1,-28.5,ECU. ,1373
6693,+23.0,1851,100, 80, 00, 11.1, 69.6,+19.1,-29.1,ECU. ,1366
6788,+22.8,1886,100, 80, 00, 11.2, 69.8,+20.6,-29.5,ECU. ,1315
6944,+22.0,1923,100, 80, 00, 11.1, 69.8,+21.3,-29.2,ECU. ,1436
7092,+22.0,1901,100, 80, 00, 10.6, 73.1,+21.9,-29.2,ECU. ,1396
7246,+21.8,1908,100, 80, 00, 10.7, 72.3,+22.3,-28.7,ECU. ,1453
7342,+21.8,1923,100, 80, 00, 10.7, 73.3,+22.4,-29.0,ECU. ,1461
7490,+22.0,1968,100, 80, 00, 10.6, 75.9,+22.4,-28.6,ECU. ,1436
EDIT: My mod list.
AEM short ram with SPW 3" filter
3" TBE
264/272 no cam gears
HKS EVC V
WR turbo
Rnr IC w/ UR piping t-bolts
Hope this helps somehow
EDIT: My mod list.
3" TBE
HKS EVC V
WR turbo
Originally Posted by dryad001
On my log, yes.
(see: maxed stock injectors above 6500, @ 18 psi.)
WarmPepsi
Oct 2, 2005 08:11 PM
