What is an acceptable knock count?
Old Aug 25, 2005 | 01:40 PM
tcarretti's Avatar
I was wondering what most people running the PowerFC would consider an acceptable knock count under WOT runs.
I know that extremely hot weather contributes to higher knock as well as sub standard fuel and overly aggressive tuning.
Just wondering what is considered "safe" parameters using the PowerFC and the OEM knock sensor.
Thanks,
Tony
Old Aug 26, 2005 | 02:58 AM
ASTROEVO's Avatar
well it will flash the check engine light at 60.... i get nervous when it does that.. but it is using the stock knock sensor that is insaneley sensitive....
Old Aug 26, 2005 | 03:32 AM
tcarretti's Avatar
So then a knock count between 10 and 20 could be considered pretty acceptable?
That's the highest I've seen so far and just wanted to make sure that I was in a safe range.
Thanks,
Tony
Old Aug 26, 2005 | 03:34 AM
ASTROEVO's Avatar
I would have to say that would be ok!..... I have a crank pulley on my car... and thats what I think makes some extra noise.... try running a gallon of race gas with your 93 octane... and your knock wont go over 5
Old Aug 26, 2005 | 03:56 AM
Karash's Avatar
20 is fine I would say.
On race gas I never see past 10...and thats at WOT.
Old Oct 7, 2005 | 08:35 AM
Derek888's Avatar
My knock always has that "l" sign next to it. Do I need to go WOT to see if it read a number?
Old Oct 7, 2005 | 08:40 AM
Karash's Avatar
click one time "up" and you should see peak values there.
Old Oct 7, 2005 | 11:15 AM
fastskyline's Avatar
i had a power fc on my skyline and it would read between 10-20 pretty often...nothing to worry about IMO all the japanese guys used to tell me not to worry about it until 60-70
Old Oct 8, 2005 | 08:07 AM
evotino's Avatar
Has anybody tried an aftermarket knock sensor? It would be nice to have two for a little more safety.
Old Oct 8, 2005 | 01:05 PM
Derek888's Avatar
Does it record peak value from the last WOT?
Old Oct 8, 2005 | 01:09 PM
evotino's Avatar
Peaks are recorded until you turn off the ignition or exit peak mode. It doesn't distinguish WOT from normal throttle, although most peaks would occur at WOT.
Old Oct 8, 2005 | 01:14 PM
robertrinaustin's Avatar
From: Work - New York, Alaska, Mexico or the Caribbean. -Home - Tx Hill Country
and you can reset peak by pushing the right button when in peak hold.
Old Jul 28, 2010 | 05:39 PM
juanpdu's Avatar
on my evo 5 rs i tuned it to stay below 40-45 better if you leave it below 30. when it gets to 60 value the car detonates and hear knocking pistons. with crap gas here in uruguay south america at 21psi stock turbo and 5 degrees of timing at wot from 4k to 6k and then climbing till 7700rpm to 12 degrees had 40 value in knock activity. good luck on tuning
Old Aug 24, 2010 | 04:36 AM
Evo1ved's Avatar
I was / occasionally get knocks up in the 80's
But as mentioned 60 or below is acceptable but worth paying attention to maybe speaking to your tuner is a good idea
Old Sep 15, 2010 | 03:41 PM
gavi101's Avatar
It has to be below 60 anything higher is considered dangerous.
My 6 is tuned and my knock doesnt go past 5
