My 1st Datalogs
I take it the rpm are varying because this is a multiple gear pull. Try doing just a 3rd gear pull from low rpm all the way to redline. Looks like it still needs some work in the timing and the fuel. What are you tuning with?
You need a wideband
You need a wideband
with a pocketlogger.. I'm kinda new at the tuning thing and just trying to figure it all out right now.. so i should do a 3rd gear pull from low rpm to redline right?
yeah do a 3rd gear pull and log that. usually i go from 2000-7300. just to let u know on ur log that u have right now, ur running pretty dam rich with ur o2 at .94-.96 throughout. u want to bring it down to around .91-.93 dependining on how safe/aggresive the tune is and on ur driving conditions. and it looks like ur timming is all messed up. u want the timing to climb and peak without dropping at certain RPMs. im still kinda new to this stuff so if im wrong in anything a guru can correct me!
i expected to be rich.. since i just put in a 255 fuel pump to go with the 272 cams that recently went in.. basically i'm just trying to figure out the pocketlogger and how to read all the data then i plan on getting a safcII and having a friend help me tune alittle...
your log looks pretty good. the only spots i would try to improve on is from 3400-4400 rpm. you should try coming into peak tourqe at around .96v and see if that keeps your timing above 5. i would add +2 at 3445rpm and +1 all the way to 4434rpm. repost the log so we can check it out after you change it .
