txs tuner reading lambda
Old Sep 5, 2005 | 09:44 AM
SlowCar's Avatar
is there any cons switching the txs tuner to read lambda instead of afr?
Old Sep 5, 2005 | 09:55 AM
MalibuJack's Avatar
As long as you understand what the value means, then there's no issues whatsoever..
Old Sep 5, 2005 | 10:21 AM
SlowCar's Avatar
I might be injecting some methanol in......and it burns 6.5:1afr whereas gas burns 14.7:1afr...one has to know the exact ratio for using afr. Lambda reading might be better for measuring rich/lean?
Old Sep 5, 2005 | 12:56 PM
MalibuJack's Avatar
Lambda reading should give you a better read of the optimum mixture for blended fuels, I was thinking the exact same thing since I am retrofitting one of my cars for E85
Old Sep 5, 2005 | 02:08 PM
SlowCar's Avatar
so i will just have to switch the dip switch for lambda on the tuner.....would any "free air calibration" have to be done??
Old Sep 6, 2005 | 06:02 PM
SlowCar's Avatar
bump
Devin LeBlanc
Nov 21, 2013 12:49 AM
LeeC
20
Jul 20, 2010 09:15 PM
racer135
Jun 4, 2008 04:11 AM
BSREVOLUTION
11
Feb 28, 2005 04:29 PM
sgplancer
13
Jul 28, 2004 05:20 PM
