First UTec log
Old Sep 6, 2005 | 06:46 PM
HiRevnVIII's Avatar
First UTec log
without a wideband and a map sensor is this all just useless information?
I'm just wondering, im anewb to tuning. The only mods i have are a K&N intake (i know) and a hallman mbc. My boost gauge is broken and only reads 14 psi but i know its higher because i hit fuel cut. What information can i take away from this log if any. thanks.
rpm map MAF TPS load knck ign#1 Inj#1 modig mod boost Mod
....................Hz % site cnt deg duty deg. fuel (OL) MAFhz
1614 +28.4 113, 15, 00, 00, +28.0, 4.0, ECU. , +0.0,ECU. , 118
1659 +28.4 208, 18, 00, 00, +28.0, 10.0, ECU. , +0.0,ECU. , 295
1654 +28.4 206, 64, 00, 00, +12.1, 8.0, +8.4, +0.0,500.00, 239
1718 +28.4 265, 97, 10, 00, +12.1, 8.0, +8.1, +0.0,500.00, 207
1783 +28.4 284,100, 10, 00, +12.0, 8.0, +7.9, +0.0,500.00, 234
1878 +28.4 209,100, 10, 00, +12.1, 9.0, +7.6, +0.0,500.00, 280
1913 +28.4 269,100, 10, 00, +13.2, 9.0, +7.4, +0.0,500.00, 287
2002 +28.4 275,100, 10, 00, +13.2, 10.0, +7.1, +0.0,500.00, 275
2039 +28.4 284,100, 10, 00, +13.1, 10.0, +6.8, +0.0,500.00, 281
2109 +28.4 337,100, 10, 00, +13.3, 11.0, +6.6, +0.0,500.00, 334
2171 +28.4 312,100, 10, 00, +12.2, 11.0, +6.3, +0.0,500.00, 316
2252 +28.4 358,100, 10, 00, +13.2, 12.0, +6.0, +0.0,500.00, 352
2364 +28.4 340,100, 10, 00, +12.2, 13.0, +5.4, +0.0,500.00, 318
2382 +28.4 399,100, 10, 00, +12.4, 14.0, +5.0, +0.0,500.00, 336
2495 +28.4 355,100, 10, 00, +12.3, 14.0, +4.4, +0.0,500.00, 358
2538 +28.4 450,100, 10, 00, +11.3, 15.0, +4.0, +0.0,500.00, 361
2645 +28.4 445,100, 10, 00, +11.3, 16.0, +4.0, +0.0,500.00, 386
2673 +28.4 526,100, 10, 00, +10.2, 17.0, +4.0, +0.0,500.00, 413
2743 +28.4 519,100, 10, 00, +9.2, 18.0, +4.0, +0.0,500.00, 501
2836 +28.4 655,100, 10, 00, +8.2, 20.0, +4.3, +0.0,500.00, 446
2918 +28.4 640,100, 10, 00, +6.4, 22.0, +4.7, +0.0,500.00, 716
3008 +28.3 776,100, 10, 00, +5.3, 25.0, +5.0, +0.0,500.00, 681
3106 +28.3 494,100, 10, 00, +5.4, 29.0, +5.0, +0.0,500.00, 632
3202 +28.3 856,100, 10, 00, +5.5, 31.0, +5.0, +0.0,500.00, 686
3323 +28.3 576,100, 10, 00, +5.4, 35.0, +5.2, +0.0,500.00, 739
3450 +28.3 807,100, 10, 00, +5.5, 38.0, +5.6, +0.0,500.00, 686
3584 +28.3 853,100, 10, 00, +5.5, 42.0, +5.8, +0.0,500.00,1126
3728 +28.3 1070,100, 20, 00, +5.6, 44.0, +5.9, -1.4,500.00, 798
3835 +28.3 1196,100, 20, 00, +6.5, 46.0, +6.6, -1.7,500.00, 798
3940 +28.3 1144,100, 30, 00, +6.7, 47.0, +7.4, -1.7,500.00, 889
4125 +28.3 1179,100, 40, 00, +6.5, 49.0, +8.0, -1.7,500.00, 946
4273 +28.3 938,100, 40, 00, +6.6, 50.0, +8.1, -3.5,500.00, 954
4334 +28.4 1048,100, 40, 00, +6.7, 51.0, +8.2, -2.3,500.00,1041
4510 +28.3 1246,100, 40, 00, +7.7, 52.0, +8.4, -3.7,500.00,1269
4578 +28.3 1213,100, 40, 00, +6.6, 54.0, +8.7, -3.5,500.00,1024
4714 +28.3 1259,100, 40, 00, +7.9, 55.0, +9.1, -3.9,500.00,1162
4916 +28.1 1193,100, 50, 00, +8.6, 57.0, +9.2, -5.5,500.00,1322
4960 +28.3 1246,100, 50, 00, +8.1, 58.0, +9.2, -7.1,500.00,1275
5120 +28.3 1416,100, 50, 00, +8.7, 60.0, +9.2, -7.1,500.00,1157
5265 +28.3 1272,100, 50, 00, +8.8, 60.0, +9.2,-10.3,500.00,1121
5324 +28.3 1385,100, 60, 00, +8.7, 62.0, +9.4, -8.9,500.00,1381
5428 +28.3 1483,100, 60, 00, +10.0, 63.0, +9.7,-13.4,500.00,1207
5574 +28.3 1424,100, 70, 00, +9.9, 65.0, +9.3,-11.6,500.00,1315
5727 +28.3 1424,100, 70, 00, +11.0, 65.0, +9.4,-13.8,500.00,1146
5767 +28.3 1445,100, 80, 00, +13.1, 64.0, +9.6,-13.8,500.00,1358
5868 +28.3 1488,100, 80, 00, +13.2, 68.0, +9.9,-13.8,500.00,1381
5995 +28.3 1552,100, 80, 00, +14.4, 68.0,+10.5,-14.1,500.00,1344
6093 +28.3 1449,100, 80, 00, +15.4, 69.0,+10.5,-15.6,500.00,1344
6195 +28.3 1510,100, 80, 00, +16.1, 68.0,+10.6,-17.2,500.00,1322
6253 +28.4 1602,100, 80, 00, +17.1, 68.0,+10.7,-16.9,500.00,1412
6349 +28.3 1607,100, 80, 00, +18.1, 68.0,+11.1,-17.1,500.00,1288
6435 +28.3 1672,100, 80, 00, +19.4, 70.0,+11.4,-17.2,500.00,1344
6510 +28.3 1557,100, 90, 00, +19.4, 72.0,+11.8,-17.3,500.00,1308
6613 +28.3 1533,100, 90, 00, +20.5, 71.0,+12.6,-17.3,500.00,1308
6720 +28.3 1712,100, 90, 00, +21.6, 74.0,+13.0,-17.3,500.00,1262
6802 +28.3 1718,100, 90, 00, +22.2, 72.0,+13.2,-17.3,500.00,1308
6915 +28.3 1694,100, 90, 00, +22.2, 73.0,+13.3,-17.3,500.00,1420
6988 +28.3 1597,100, 90, 00, +24.4, 73.0,+13
yes i will get rid of the KN but the bottom half of my airbox broke when separating the MAF from the box. one of the nut got stripped and cracked a big piece off the box. thanks for the info.
Old Sep 6, 2005 | 06:53 PM
Widebandphillip's Avatar
duty cycle on the stock injectors is amazingly low. I'm wondering what the afrs are.
Old Sep 6, 2005 | 07:05 PM
EVO8LTW's Avatar
Where did you get the tune? If I'm reading the columns correctly, it looks like you have pulled out a large amount of fuel up top (17%), but that your timing is pathetically low (only 13 degrees up top). I can't see anything in the knock column, so I guess the timing is intentionally low, probably to stay out of knock. That's the best I can tell, but I'm not sure if I'm reading the columns right. It's hard to see in this format.
Old Sep 6, 2005 | 07:06 PM
dryad001's Avatar
Good god get rid of the K@N, look at how jumpy the Maf Hz are, or you have one hell of a boost leak.
Old Sep 6, 2005 | 07:17 PM
HiRevnVIII's Avatar
the map im using is the newest 1.7 map off the the turboxs website. it is their base map. think i need a map sensor.
Old Sep 7, 2005 | 07:35 AM
sgplancer's Avatar
Ok, you seem like a nice enough person, so let me try and help.
First and foremost, you need a working boost guage. You can either fix/replace the one you have, or get a gm map sensor and harness for the utec. All of the parts can be found on this post:
https://www.evolutionm.net/forums/sh...ght=molex+part
Once you have a working boost reading, you need to check for boost leaks. Based on your maf hz, it seems that you may have one. You will definately be able to tell when your boost reference (map or gauge) is working.
Then you may want to get the wideband hooked up. Tuning for a target afr is very, very difficult if you don't have an afr reading. My recommendation from here is based on an afr source output.
I used the tool in this post for my logging/map building:
https://www.evolutionm.net/forums/sh...&highlight=UCC
The UCC program allows you to build timing maps based on a mod of ECU in the timing map. This is basically map 0 or pass through. You will definately need to do some logging under map 0 to get a feel for what your ecu wants to see/use.
Once you have your timing table done, you will adjust your afrs to get to your target. This can be done by either adding or subtracting fuel.
So the recap is:
1. get a solid boost signal
2. fix any/all boost leaks
3. get a wideband
4. build a timing map
5. build the fuel map to target afrs
This is just my .02 with some helpfull posts. BTW, do a search for other questions in the future. Hope this helps.
Old Sep 7, 2005 | 09:22 AM
HiRevnVIII's Avatar
that is exactly what i was looking for. Thank you!
