Wish me luck tomorrow with meth tuning
Old Sep 18, 2005 | 07:23 PM
SlowCar's Avatar
What water injector size are your using for the injection? 100 or 150psi pump?
Also, to get a 50/50 water methanol mix, you have to mix a 60% volume methanol and 40% volume water (water = ~1g/cc and methyl alcohol = ~0.8g/cc)
Old Sep 18, 2005 | 07:34 PM
dryad001's Avatar
It's the 150psi @/4.9gph injector
I'm going to keep it straight meth, I found it close to my house for 1.87/gal
Old Sep 18, 2005 | 07:55 PM
SlowCar's Avatar
the nozzles are rated at 4.9gph@100psi for water. At 150psi that will be ~(150/100)^0.5 *4.9 = 6gph.....methanol being less viscous, flow rate is higher than 6gph......lots of leaning out to do
Old Sep 19, 2005 | 06:04 PM
dryad001's Avatar
Thats what i figured also. Getting kinda psyched about it. But headstuds come first. So by about noon or so the heat soak and retorque should be done, then we flip the switch.
Old Sep 21, 2005 | 06:53 PM
dryad001's Avatar
Didn't get the headstuds in today, had to head to the tool shop and re supply my work toolbox from last week. Plus I also made a pressure tester for the boost switch in the car to see what the actual pressure is when the injection starts.
Old Sep 22, 2005 | 09:21 PM
dryad001's Avatar
Headstuds in and ready for a few heat cycles then re-torque or do you think Im good at 80ft/lb?
I figured out the wiring problem, it seems I didn't have a good ground, I was using a different ground to test the system.
Old Sep 22, 2005 | 09:28 PM
Jin4g63's Avatar
I want one!!! goodluck with the tuning
Old Sep 22, 2005 | 09:35 PM
joeymia's Avatar
I haven't fully tuned for mine because I have no installed my headstuds either
06_MR_FTW
Pacific Northwest
11
Jan 30, 2013 08:33 PM
cmross13
Nov 7, 2012 10:11 AM
05ah8james
14
Oct 23, 2010 09:09 PM
raasfaas
33
May 20, 2009 10:39 AM
EvoTech
13
May 24, 2006 11:35 AM
