First log / couple of questions.
Old Sep 21, 2005 | 05:24 PM
WarmPepsi's Avatar
first, a 4th gear run.
Code:
 2487,+26.6, 131, 0, 00, 00, 10.5, 4.3,ECU. , +0.0,ECU. , 202
2415,+26.3, 321, 26, 00, 00, 10.7, 10.7,ECU. , +0.0,ECU. , 270
2204,+26.3, 263, 28, 00, 00, 10.5, 9.3,ECU. , +0.0,ECU. , 248
2225,+26.6, 274, 30, 00, 00, 14.4, 9.3,ECU. , +0.0,ECU. , 290
2281,+26.6, 304, 35, 10, 00, 14.8, 12.4,+14.8, +0.0,ECU. , 331
2349,+26.6, 329, 48, 10, 00, 14.7, 13.4,+14.8, +0.0,ECU. , 349
2415,+26.6, 350, 69, 10, 00, 13.6, 14.4,+14.8, +0.0,ECU. , 393
2476,+26.3, 373, 95, 10, 00, 13.3, 15.4,+14.8, +0.0,ECU. , 397
2560,+26.3, 391,100, 10, 00, 13.0, 16.9,+14.8, +0.0,ECU. , 443
2641,+26.1, 453,100, 10, 00, 13.0, 18.0,+14.8, +0.0,ECU. , 348
2730,+26.1, 502,100, 10, 00, 13.1, 19.9,+14.8, +0.0,ECU. , 419
2832,+26.6, 497,100, 10, 00, 13.0, 22.4,+14.5, +0.0,ECU. , 461
2931,+26.1, 615,100, 10, 00, 12.4, 24.3,+14.1, +0.0,ECU. , 468
3041,+26.3, 690,100, 10, 00, 12.5, 27.6,+13.6, +0.0,ECU. , 581
3174,+26.3, 730,100, 10, 00, 12.6, 31.0,+13.1, +0.0,ECU. , 566
3323,+26.1, 807,100, 10, 00, 12.5, 34.4,+12.8, +0.0,ECU. , 623
3447,+26.1, 880,100, 20, 00, 12.5, 35.0,+10.0, +0.0,ECU. ,1059
3607,+25.9, 891,100, 20, 00, 12.9, 36.5, +9.8, +0.0,ECU. ,1106
3745,+25.5, 954,100, 30, 00, 12.9, 38.4, +8.6, +0.0,ECU. , 838
3912,+25.7, 984,100, 30, 00, 13.3, 40.5, +9.5, +0.0,ECU. ,1256
4025,+26.1,1057,100, 30, 00, 13.4, 43.3,+10.1, +0.0,ECU. , 909
4224,+25.9,1070,100, 40, 00, 12.8, 48.9, +9.1, +0.0,ECU. , 946
4317,+26.1,1068,100, 40, 00, 11.9, 50.9, +9.1, +0.0,ECU. ,1141
4450,+26.1,1057,100, 40, 00, 11.7, 51.2, +8.7, +0.0,ECU. , 936
4629,+25.9,1182,100, 40, 00, 11.8, 54.8, +8.5, +0.0,ECU. ,1351
4748,+26.1,1160,100, 50, 00, 11.4, 55.9, +7.1, +0.0,ECU. ,1308
4880,+26.6,1196,100, 50, 00, 11.4, 57.6, +7.3, +0.0,ECU. ,1344
5042,+26.8,1288,100, 50, 00, 11.4, 59.6, +7.5, +0.0,ECU. ,1179
5159,+26.8,1237,100, 60, 00, 11.3, 60.5, +7.9, +0.0,ECU. ,1388
5265,+26.8,1362,100, 60, 00, 11.4, 62.2, +8.2, +0.0,ECU. ,1428
5402,+26.3,1436,100, 60, 00, 11.5, 63.7, +8.2, +0.0,ECU. ,1436
5527,+26.1,1453,100, 70, 00, 11.6, 66.5, +8.3, +0.0,ECU. ,1373
5668,+25.9,1428,100, 70, 00, 11.5, 67.5,+10.3, +0.0,ECU. ,1562
5807,+26.1,1515,100, 70, 00, 11.2, 70.7,+11.5, +0.0,ECU. ,1602
5941,+25.9,1497,100, 80, 00, 11.2, 73.2,+11.7, +0.0,ECU. ,1358
6071,+26.1,1515,100, 80, 00, 11.2, 73.8,+12.3, +0.0,ECU. ,1488
6195,+25.9,1572,100, 80, 00, 11.1, 75.6,+13.1, +0.0,ECU. ,1470
6313,+26.1,1562,100, 80, 00, 11.1, 75.2,+13.8, +0.0,ECU. ,1724
6410,+26.1,1618,100, 80, 00, 11.5, 77.0,+14.7, +0.0,ECU. ,1712
6561,+25.9,1628,100, 90, 00, 11.4, 76.9,+15.4, +0.0,ECU. ,1497
6666,+26.3,1672,100, 90, 00, 11.2, 81.4,+15.6, +0.0,ECU. ,1592
6802,+25.7,1683,100, 90, 00, 11.2, 82.8,+15.8, +0.0,ECU. ,1582
6901,+25.5,1672,100, 90, 00, 11.1, 82.0,+15.9, +0.0,ECU. ,1760
7017,+25.5,1712,100, 90, 00, 11.1, 82.8,+16.2, +0.0,ECU. ,1612
thats the stock map, etc.
Now my questions. I'm runnin a hallman, set to 18 til i get a feel for things, walbro, also yes, i have a dreaded intake.
When i run the "stock map" turbo xs gives, it's not lookin too bad, it's nowhere near as rich as it was.
Now, when i ran the stock (ecu) complete (map 0), it ran PPPPPPIIIIGGGG rich, like 9.3 a/f, above 6500 it'd max the injectors. The stock map has nothing pulled on the fuel map, why is it so much leaner (see: better), just the timing?
Secondly, how in the WORLD do you guys ever end up hitting some of those load cells... i get a path about 4-5 tall in a diagonal line going down, and can't hit anything else.
Only time i had any knock was when i put the pedal down on the highway in 6th, tried to log a bunch, but i'd log for 4-5 minutes and the computer didn't like the vibration of the seat, even though it was sittin on some shirts to cushion it.
Third, i think i'm confused on the headings on a few, the column to the right of the injector duty is what?(timing advance?) then after that is fuel pull, then boost? (not using utec for boost). Everything is so much ecu run still, i'm not 100% sure
Just wanna make sure i got everything understood.
Thanks guys.
Old Sep 21, 2005 | 05:30 PM
WarmPepsi's Avatar
also, in the utec, i went in and pulled the stock rev limit down to 7400, just for a little safety right now...
but when i did the run, i hit fuel cut once, and thats when i let off, but my logs show 7017 as the top rev. I have to use a usb adapter to hook to the 0 pin cable, could that be slowing it down? when i watch it live, its live, but when i look at the logs, i wonder
Old Sep 21, 2005 | 05:43 PM
dryad001's Avatar
The column to the right of the IDC is timing. Looks like your using the MPS logger, right?
Old Sep 21, 2005 | 05:44 PM
WarmPepsi's Avatar
yes sir. with an innovate wideband standalone gauge.
Old Sep 21, 2005 | 05:51 PM
dryad001's Avatar
Same thing I use. I noticed the lag of the connection also, but I just figured looking at 2 things at once and paying attention to the road was the culprit. Everything seems fine when I go thru a non-logging pull, just looking at the gauge.
Old Sep 21, 2005 | 05:54 PM
WarmPepsi's Avatar
gotcha. i'm just surprized how much a difference the two maps made, with really not that much different. runs a bunch better, but definatly needs fine tuning.
Old Sep 21, 2005 | 06:07 PM
WarmPepsi's Avatar
also, what is the difference between the 3rd and last columns? i've never seen a full naming thing to know the term, but it's maf voltage, is the first one what the car is looking for, then the last one what it really gets, or how does that work?
Old Sep 21, 2005 | 06:26 PM
dryad001's Avatar
The 3rd column is what the MAF is seeing in Hz "air volume" and the last column is what the uTEC is putting as the MAF signal to the ECU.
Old Sep 21, 2005 | 06:28 PM
WarmPepsi's Avatar
hrm, ok... i guess the only one i ever looked at when i saw aftermarket intakes was the last one, and it was all over the place, as mine is now. But it's actually seeing it relatively well. ( or so i think, right? )
Old Sep 21, 2005 | 06:51 PM
dryad001's Avatar
In my logs (some are posted up here) my 3rd column is pretty smooth but the last column jumps all over the place, Im guessing thats normal.
Old Sep 23, 2005 | 02:18 PM
WarmPepsi's Avatar
bump.
Old Sep 23, 2005 | 06:04 PM
SoR's Avatar
SoR
Sorry about little offtopic but did you have a TSX before WarmPepsi? I kind of remember that nickname from clubtsx (which doesn't exist anymore).
Old Sep 23, 2005 | 06:07 PM
WarmPepsi's Avatar
haha, nah, it's cool. I still have an rsx, don't know if i ever posted on clubtsx or not, but if you ever were on clubrsx, you've seen me around.
Old Sep 23, 2005 | 06:27 PM
SoR's Avatar
SoR
Could be there too
Old Sep 25, 2005 | 11:41 AM
MalibuJack's Avatar
If your talkng about the TXS stage 1 map.. Using open loop fueling completely takes over for the stock ECU, therefore the fuel map is also different than the stock Stage0 map. Thats why it runs richer in the MAP0 position compared to the MAP1 position (even though the map is filled with 0's for fuel, its really 0% added or removed from the UTEC background map) which is generally leaner than the stock ECU map.
Timing on that map is pretty tame, in some cases tamer than the stock ECU timing, but generally similar. The difference is consistency, since the UTEC does its job doing what you tell it to, the timing and fuel you tell it to use will always do that. With the stock ECU it maintains ignition (knock) trims and Fuel trims.. Both of those could effect performance of the car so on different days it could feel weaker or stronger.. the UTEC is amazingly consistent.
