SAFC2 or UTEC
Originally Posted by modvp
In opinion you should go with a unit that has control over timing such as the utec. The xede is also a good product. Shiv has staged maps that appear to be pretty good.
Originally Posted by MalibuJack
Just be aware that the PowerFC is a standalone unit and It may not be able to pass an inspection in your state if it eliminates OBD-II
What I find interesting is this is posted in the UTEC forum, and you are getting pretty honest unbiased answers.. I think the UTEC users probably have the most open mind when it comes to this stuff..
I had an Autronic and now I have Utec. You have to ask yourself how much mods you plan to do. If simple bolt ons are all you going to get, I think you should get a reflash or SAFC. But if you are constantly modding your car and you want to squeeze every bit of juice from them, go with something moe flexible, such as UTEC, XEDE, or even stand alone like Autronic, AEM, or Power FC. ECU+ is more like a product in the middle ground between XEDE and SAFC. It controls timing like XEDE, but it doesn't have very high resolutions.
Once you decided how you see yourself modding the car, you just have to choose which interface to use.
I am now using UTEC and I think it suite my needs very well. Stand alone is overkilled for me, and I would rather spend more time tuning my car at WOT than tuning its drivability.
Good luck!
Good luck!
