No reflash needed?
No reflash needed?
My local tune shop (not going to name them),said that reflashing for bolt-ons is unnecessary that it justs adjusts ur ecu to not throw the check engine light ! is this true in a sense? i had my scooby done there an was happy with the results but had a "cel" w/ no mentioning of reflashing it! am i missing something here ?
On non turbo cars this is fairly true because airflow doesn't change that much.
However.....a reflash for specific mods like turbo back exhaust ...on a turbo car make a big difference. The flash also leans out the pig rich air fuel ratio that the factory flash has programed. Definately worth getting a flash if you have the basic bolt ons completed.
This info you have is not accurate
A good flash is set up to tune the a.f and ign timing tables to match the mods you are adding to achive a smooth power delivery - additional power and saftey
Avoiding a cel is usually not a benefit of flashing unless your tune is grossly off without a flash
I was told by somebody that the stock ECU compenstates for a considerable range of conditions. Therefore it is not necessary if you are not doing anything to significantly change the set up such as adding a new turbo or increasing the boost significantly.
Is this true?
Is this true?
Is this true?
Is this true?
