ECU PLUS 1st STEPS
Old Oct 19, 2005 | 10:32 AM
BADEVO's Avatar
ECU PLUS 1st STEPS
OK guys, all you guys that already have ECU plus what did you first do when you got it all plugged up?
Settings wise I mean.
Old Oct 19, 2005 | 11:23 AM
Ivan_C's Avatar
Ok, for the first go. Turn the car to run, but don't start. Go into the program and make sure the sensors are correct(cam angle and such) and set your injector size. Go through the fuel and timing tabs and make sure they are 0. If you have a silver box, set the knock saftey settings. Once everything looks good, start a log, then start the car. Let the car idle and warm up, make sure it reads/logs all of the sensors.
When you're happy the car is running good, grab a friend to run the laptop. Go do a couple 2nd gear base runs. Park somewhere and look over the logs. Make small adjustments until you're comfortable with the program. Get the fuel set before you start with timing. For second gear 11.0-11.5 is fine, 3rd and 4th will naturally be a little richer(safer).
Good addins are wideband and boost. I also have EGT.
Don't be overwhelmed with the 250rpm increments, until your comfortable make 500 or 1000 rpm changes, ie 4000,4250,4500,4750 = -2% | 5000,5250,5500,5750=-3%
That should get anyone through the initial startup and then some.
Old Oct 20, 2005 | 07:53 AM
EvilDylan's Avatar
when i first wired my ECU + up and started teh car it ran like crap and i was getting a CEL. This was because the settings in the cam angle/crank angle sensor default to a 1999 DSM. I changed it over to EVO and it was perfect. next i just made sure all the logs were coming through. and that was it.
Old Oct 20, 2005 | 04:15 PM
tlcoll1's Avatar
I've actually switched the defaults over to the EVO now. It defaults to "whatever car I own" (and I just bought an EVO).
Tom
Old Oct 20, 2005 | 04:17 PM
Kronik's Avatar
Congrats on the new car, Tom!
Old Oct 20, 2005 | 07:43 PM
Ev0ikon's Avatar
Talking
Tom
WHOA!
Congrats!
Old Oct 23, 2005 | 10:32 AM
ksquad97's Avatar
not to get off topic but do you need the palm pilot and a laptop for this? or either or
Old Oct 23, 2005 | 02:59 PM
Dyno4mance's Avatar
Just a laptop...
Old Oct 23, 2005 | 03:02 PM
BADEVO's Avatar
And a good tuner like Andrew.........
Old Oct 23, 2005 | 07:40 PM
EvilDylan's Avatar
or a person like me to force the ECU + onto andrew's dyno multiple times haha.
Old Oct 24, 2005 | 07:56 AM
ksquad97's Avatar
is ecu + user friendly for a first time tuner? i really liked the k-pro program that hondata made for the rsx's, i'm hoping this is like that.
Old Oct 24, 2005 | 09:27 AM
G20's Avatar
G20
Yes! It's windows based software with dialogs providing options and settings just like when you use Microsoft Excel or Word.
Old Oct 24, 2005 | 10:01 AM
BADEVO's Avatar
Dylan,
I am having Andrew do my clutch then I'm putting it up on the DYNO to tune the ECU Plus.....maybe you could swing through when we do it.
