MAFTpro Subforum
MAFTpro Subforum
I started a thread in the UTEC forum about a product called MAFTpro. It seems to have become pretty popular and would like to request its on subforum. If you able to create this subforum please move this thread into it:
https://www.evolutionm.net/forums/sh...d.php?t=162727
Thank You
Thank You
I'm here.. can't wait until I can get my grubby little hands on one.. And I plan on testing it with all of the available configurations, GM, Ford MAF, and speed density since I can easily switch between things now..
Anyone know if there will be a package created for the Speed density with the Pnp harness, and sensor and for a little cheaper then the MAFT with all the fuel options etc so I can just use SD with my UTEC?
The speed density option is as cheap as will get. They don't have any plans that i know of for a unit just for the conversion. If you want to use this with UTEC your going to have to spend sometime with your AFR maps in UTEC. Once Jack gets his hands on it I am sure it will be much easier. I did not have the patience nor all the data that jack has on the stock MAF to get this working on UTEC. I decided a flash was a better option for me since Jestr is pretty close to me. We got my car on the dyno set the timing that worked best for me then dialed the AFR in
Yah I'm back from Ohio, don't have the time to follow up on getting a unit until after my honeymoon.. But I'm definitely going to work on some calibration files and configs.. I am attempting to get more info on the connector, if not, I will make my molds available for the connectors needed to produce PNP harnesses..
This will have to serve as the temporary subforum.
Anyhow just alleviated my tip in issue and this thing drives 250% better!
Before between shifts it would fall on it's face. Now it's nice and smooth. It is amazing how much different the tune is than Joeys. His mapping was off from mine by a longshot.
