DTEC Question: can I connect the MAP
Old Oct 20, 2005 | 03:19 PM
lbcevo's Avatar
sensor to a DTEC and then connect the DTEC to my UTEC in order to use the DTEC as a boost gauge and log boost on the UTEC simultaneously?
Old Oct 21, 2005 | 12:25 PM
MalibuJack's Avatar
No.. It doesn't work that way. .However I think you can wire up the sensor so it will be connected to both the UTEC and DTEC and it should work ok..
