Installed UTEC, no boost.
Old Oct 31, 2005 | 10:07 AM
sleet's Avatar
I installed the UTEC last night and started up the car, I put it on map 0 and went for a drive. I'd start to hit the gas but I can't hit boost, the second it starts to hit it just slows the car down. Any idea why this is happening?
Old Oct 31, 2005 | 10:39 AM
EvoTech's Avatar
Did you hook up the bleed valve?
Old Oct 31, 2005 | 10:40 AM
rjdEVO's Avatar
Did You Hook Up The Mbc Too
Old Oct 31, 2005 | 10:41 AM
rjdEVO's Avatar
When I Hooked Mine Up, The Maf Sensor Wasn't Hooked Up Tight Enough And It Did The Same Thing
Old Oct 31, 2005 | 11:02 AM
sleet's Avatar
No, I have the Hallman MBC.
Old Oct 31, 2005 | 12:26 PM
dryad001's Avatar
Check to see where the MAF overboost is set to. Might be too low
Old Oct 31, 2005 | 01:24 PM
sleet's Avatar
Ok, I figured it out. I closed fuel looping and now the car runs just like it did before the UTEC, now i've gotta get a laptop with a serial port so I can upload a map and work off it instead of the maps on here from the previous owner. I'm still playing around with all the logging and whatnot aswell. Maybe i'll do some logging and post some stuff up for help making a new map.
