Why do WRXs have launch AND shift RPMs??
Old Nov 3, 2005 | 05:31 PM
TrinaBabe's Avatar
Im trying to figure out why TurboXS allows WRXs have three rev limiters (Launch, Shift and overrev) but we only have 2. Please tell me that ours does have a speed input??
Old Nov 3, 2005 | 05:33 PM
bleublaze55's Avatar
ya i would like to know to, any one know??
Old Nov 3, 2005 | 05:56 PM
WrX Kila's Avatar
My friend has an Sti, and I saw him take off after he got his three step programed in his CPU. I want tht Sh@t on my car if its possible.
Old Nov 3, 2005 | 06:01 PM
SilverEvo8owner's Avatar
what do you mean?
the sti has the stock fuel cut and the launch/flat foot shift rev limit.
The launch control rpms are the same as the flat foot shift. No matter what you do, when you put the clutch down, the rev limit will be you set rpm limit (ex. 5k) Pushing the clutch down on line will do the same thing as when your moving.
I have this on my Sti and i want it on my evo.
Old Nov 3, 2005 | 06:04 PM
WrX Kila's Avatar
Originally Posted by SilverEvo8owner
what do you mean?
^^^^^^^^Thats what I mean^^^^^^^^^^^^^^^
TrinaBabe's Avatar
Incorrect.... they have three setable rpm limiters. One is activated under 13 kmh I believe (Launch control), the other is activated ABOVE that speed with the clutch pushed in (Flat shift rev limit) and then a top overrev limit (When clutch is out, over rev protection).
Old Nov 3, 2005 | 06:06 PM
TrinaBabe's Avatar
The “User Constants” menu adds a “Flat Shift RPM” parameter. Launch control now has two RPM settings. Below 13 mph (20km/h) the “Launch Control RPM” setting operates. Above 13 mph (20km/h) the “Flat Shift RPM” setting operates. This allows the user to have a different launch RPM and flat shift RPM points.
There is thier wording of the same thing.
Old Nov 3, 2005 | 06:08 PM
hmmm my sti doesnt have this
new upgrade?
Old Nov 3, 2005 | 06:10 PM
TrinaBabe's Avatar
Currently I am forced to use the launch control wired to a momentary switch and I cut the top clutch wire. This meaning, I wired up a switch that when I push it, the UTEC thinks I push in the clutch, activating the launch control. When I shift, I need a much higher RPM limit (Otherwise the car will bog between shifts) but it sucks because it is the same as my over rev limit and trapping at over 123 mph means I am pretty far into the red line through the traps therefore I need it set pretty high. The other problem is the speed at which my rpms fly while floored while shifting. The rev limiter has a soft cut and a hard cut. By the time the hard cut hits it is well above the softcut limit... so say I set the limit at 8k. My car will start to cut out at 8k (So while in gear I can not pass through the traps without hitting it) but when I shift, it is too fast and will climb to around 8.5k before it hits the hard cut. Revving my stock motor/head that high worries me.
Old Nov 3, 2005 | 06:11 PM
TrinaBabe's Avatar
Do you have a UTEC???? I am not talking about the car itself This is in the UTEC forum, I am posting about the Utec controls. Not the car controls
Old Nov 3, 2005 | 06:13 PM
does the evo verison have flat shift?
Old Nov 3, 2005 | 08:15 PM
Spec C's Avatar
The sti does not have this yet, however the WRX does use this feature in the latest firmware update..
I am sure the evo will soon have this feature on its next firmware update.
Old Nov 3, 2005 | 08:53 PM
sleet's Avatar
I hope UTEC adds all this good stuff in the next update.
Old Nov 3, 2005 | 08:56 PM
dryad001's Avatar
Ohhhh I know the answer to this. It is because Txs forgot about us, when is the last time for a sti update? wrx? evo? Now why do they have a 350z utec? Money is made buy selling product not updates.
Thanks joey
Old Nov 4, 2005 | 08:43 AM
Yes i do have UTEC on my STi
