ECU+ inaccuracy LM-1 wideband reading...
Old Nov 11, 2005 | 06:36 PM
EVO8_PR's Avatar
Question ECU+ inaccuracy LM-1 wideband reading...
Well folks I ditched the SAFC 2 and have switched over to the ECU+. I have a Innovate Motorsports LM-1 to keep track of the A/F ratios. I am having trouble capturing the A/F ratio as the LM-1 unit will display 14.4-14.6 @ idle but my ECU+ will show 14.4-16.5 am I missing something with the installation. The LM-1 output have been programmed as follows 1 volt=10.0a/f and 2 volts=20.00a/f. The cable which outputs the signal has a ground to it, which I have connected to the "sensor ground" wire on the ECU+ and have also left it disconnected with not much of a difference.
Has anybody had similar problems and care to shed some light on the subject?
Log file can be downloaded here
