Utec 2005?
Old Oct 8, 2004 | 08:35 AM
The Reject's Avatar
Utec 2005?
Just as the title says, will it work? My 05 will be here any day, so I want to make sure it will work. If it needs to be updated I would be willing to test it.
Old Oct 8, 2004 | 02:46 PM
The Reject's Avatar
Bump
Old Oct 8, 2004 | 10:41 PM
whiterexman's Avatar
Bump
I would like to know also.
Actually, what about '04?
Any '04 here?
Old Oct 9, 2004 | 03:10 PM
The Reject's Avatar
Old Oct 9, 2004 | 05:30 PM
PPI's Avatar
PPI
I have the utec on my 04...no problems
Old Oct 9, 2004 | 06:16 PM
Cool, thanks.
Old Oct 10, 2004 | 07:20 AM
MalibuJack's Avatar
From what I'm aware of, there are no significant wiring changes on any of the new Evo models, AYC/ACD and other features have their own control unit and should not have any direct ECU connection, at least anything that is significant enough that the passthrough would affect it.
However most of my info is based on my knowledge of the earlier Evos which did have these features and they weren't directly integrated to the ECU.
Safest bet is wait for one of the TurboXS guys to have an opportunity to test it on a new model before attempting to install one.
Old Nov 9, 2005 | 04:32 PM
Ultimate CC's Avatar
bump any word yet on 05 software?
Old Nov 9, 2005 | 05:04 PM
Imprezd's Avatar
Everything is the same, maf sensor reads slightly different making the base map run too lean. Which is why on the site is states don't use these basemaps with the MY05+.
We have tuned several 05 lately, the problem is that no one brings a stock car to get a starting point on.
Thanks,
Jermaine@turboxs.com
Just spoke with Jermaine from Turbo XS, he said the UTEC's will work for 05s it is just that they need to be tuned for the base maps to work as they are too lean for 05s. So you would just have to add a little fuel and they will work fine.
Old Nov 10, 2005 | 12:15 AM
Gabriel J's Avatar
Thanks,
Jermaine,
How lean are we talking about? I purchased a UTEC from an '03 owner, and want to test the unit for proper function on the car. It's in the garage currently stored for the winter, I don't want to install it this spring only to find out it's junk.
My car has the basic bolt-ons (TBE, Intake, MBC..etc). How far off are you from a suitable '05 map w/TBE? -Gabe
Old Nov 10, 2005 | 11:20 AM
Nesiop's Avatar
I don't trust base maps. But yeah it works, I used the UTEC on my 03 Evo and now on my 05 MR.
Old Nov 10, 2005 | 12:50 PM
What map are you running with your MR?
Old Nov 10, 2005 | 01:04 PM
Gabriel J's Avatar
Originally Posted by Nesiop
I don't trust base maps..
Any "base" map should at least get the car running safely. I certainly didn't buy the UTEC for the base map.....I'm more interested in knowing that the base map will allow me to run up and down the street datalogging safely....
Old Nov 10, 2005 | 02:31 PM
Nesiop's Avatar
A tuned map from Pruven, but I still need to get there to get it fixed. They said they would fix the tune and I have left a few messages just no calls back.
