Front O2 Sensor w/ PFC
Old Nov 12, 2005 | 02:37 PM
firehawkta2000's Avatar
I am currently running a PFC D-jetro and just bought the Bushur GT30R turbo kit. My problem is that the Bushur kit doesn't include an 02 sensor bung on their elbow for re-installing the factory front O2 sensor. I was wondering if I even needed the front O2 with the Power FC? I noticed an option for O2 feedback while learning to use the Commander, what does this option do? Is it for some sort of closed loop feedback or possibly for idle learning? Anyone know?
Old Nov 13, 2005 | 12:45 PM
evotino's Avatar
From my understanding the option to disable O2 feedback is only used when tuning, where a wideband sensor should be used. During normal driving the PowerFC uses feedback from the O2 sensor to make adjustments.
Old Nov 13, 2005 | 01:58 PM
avngrguild's Avatar
this is my understanding as well.
Old Nov 13, 2005 | 11:57 PM
Thanks!
Old Dec 1, 2005 | 08:26 AM
Guru's Avatar
Yes you can turn it off but I usually turn it back on when done tuning as it does make things a bit smoother and helps with fuel mileage when you're not boost like crazy.
Old Apr 20, 2006 | 07:56 PM
crazyevoRS's Avatar
If your tuning is good enough, no need for it. But if you have it and it is accurate, it is even better.
THE PFC is an awesome standalone.
Old Jan 18, 2010 | 11:04 AM
tchouko's Avatar
+3 on that one...
evobanjo
Sep 15, 2010 12:55 PM
nianlala
13
Apr 20, 2010 12:56 AM
Bosshog
31
Jul 24, 2006 08:45 AM
denial
Apr 12, 2006 02:17 AM
giangi
Apr 2, 2005 09:08 AM
