Pos Lc-1?
Old Apr 11, 2008 | 09:59 AM
mrfred's Avatar
Pos Lc-1?
I thought I might be able avoid having issues with my LC-1 by doing the best possible install that I could, but alas, it might be that a POS is a POS no matter what is done. During some WOT pulls this morning, the reading was falling to 7.35 within the first few seconds of the pull. It would return to normal after the pull though, and there were no error flashes on the LED. I guess I have to dick around with it this weekend to figure out if this is something that can be fixed.
Old Apr 13, 2008 | 03:51 PM
93 3gt vr4's Avatar
i think my lc-1 is money well spent. Only find myself calibrating it before i use it. Follow the correct steps for calibration. And it should be fine.
Old Apr 13, 2008 | 10:34 PM
mrfred's Avatar
Yeah, I think I figured out this weekend that the calibration is being reset, apparently due to its sensitivity to voltage variations. I may have to add a capacitor in parallel with the LC-1 to stop the unwanted resets.
Old Apr 14, 2008 | 10:30 PM
tephra's Avatar
MrFred - if you do this can you post up info.
I think a cap is a great idea but don't really know how to size one or wiring it...
Old Apr 14, 2008 | 10:32 PM
eponti's Avatar
I don't know how many times i had to re calibrate my LC1 but it is getting very old.
Old Apr 14, 2008 | 10:40 PM
mrfred's Avatar
Yeah, I'll post up details when I figure out what's needed.
Old Apr 16, 2008 | 09:45 AM
mrfred's Avatar
Lost calibration again. Spoke with Felipe at Innovate. He was adamant that its likely a ground offset issue. I know I did a good job on grounding, and I've read enough on the forums to believe that its not always a grounding issue.
I am going to speak to an Innovate engineer in a few hours to get details on exactly what causes the calibration to go into recalibrate mode (or whatever its doing).
Old Apr 16, 2008 | 04:44 PM
tephra's Avatar
have u stopped using the serial cable?
mine hasn't lost calibration in a while now (since i stopped using the serial)
when you say lost - do you mean the Gas Type is not 41.7 anymore?
Old Apr 16, 2008 | 05:09 PM
mrfred's Avatar
Seems to happen with or without the serial cable. The fuel type is still gasoline, but the calibration gets screwed up. Some voltage spike (or significant ground offset according to Felipe who now seems to be blowing off my phone calls) is causing the unit to perform a sensor calibration run at an unintended time, e.g., just as the car is starting up or shutting down.
Old Apr 16, 2008 | 05:52 PM
tephra's Avatar
what firmware u running? 1.10 or 1.00
Old Apr 16, 2008 | 07:58 PM
mrfred's Avatar
1.00A. I've heard that 1.10 doesn't fix it.
Old Apr 16, 2008 | 08:01 PM
3geclipse's Avatar
i been using my lc 1 for three months,never have any issue with it,check all your wiring again and make sure everything is perfect =)
Old Apr 16, 2008 | 08:46 PM
tephra's Avatar
MrFred get 1.10 - it changes the required amount of time that the calibration button needs to be held down.
Old Apr 19, 2008 | 07:08 AM
GEORGE_23's Avatar
how long does the calibration to complete ??
1-2 seconds? or more?
Old Apr 19, 2008 | 07:48 AM
tephra's Avatar
couple of seconds
