problem with injector scaling to 720cc
Originally Posted by tlcoll1
gunzo is one of my, er, more demanding users. But hey, I'll make you (and anyone else) an offer. Your favorite feature in the ECU+: any feature you want, no matter how much work, I'll do it. $100 per hour. Just tell me when to start!
Tom
Tom
Oh also, MAF scaling becomes difficult for very large injectors due to the dead time of the injectors, but also something everyone overlooks.. If your MAF value drops below 20hz or so, the car drops into open loop operation and runs in a very rudamentary speed density mode and is very rich.. (you can hear the relay in the engine compartment clicking on and off as idle hunts too when that happens, thats the IAC trying to adjust)
Originally Posted by MalibuJack
If your serious about that, and can give me an idea how much time/effort your looking at.. I'll finance some of the features for the benefit of the community..
--Dan
Mach V
MachEVO.com
Its interesting you mention this.. There are two additional things that you will gain by direct injector control, you will be able to override the Fuel Cut, MAF cut, and Rev Limiter on the stock ECU.. That alone should be a good enough reason..
additionally, Direct Ignition control would also eliminate the issues with occasional P0300 codes being thrown at part throttle driving when you have larger injectors and transition frop closed loop to open loop..
Tom
Tom
Interesting thread. My 720's are on the way, and I just started getting the P300 code since I installed the ECU+ about a week and a half ago. I've never had it before now (stock injectors).
I will be trying 880's this friday my ecu is flashed for the stockers. Any suggestions in order to make the car driveable as the max is 780's? It will be around 2 weeks before i take the car to be flashed for 880's in the mean time i want to start playin with it and maybe try to tune it for now for WOT runs.
So scaling for 880s is overkill from what i see. Would something like 650cc scaling and adjusting from there make the 880's driveable would i be able to reach my target air fuels?
Thanks in Advance
Joel
Thanks in Advance
Joel
Raceghost
Jun 1, 2016 12:30 AM
dryad001
Oct 21, 2007 06:26 AM
zlancer
Lancer Troubleshooting
Apr 1, 2003 05:13 PM
