Help with map
Old Nov 20, 2005 | 09:46 AM
VIIImylunch's Avatar
what numbers are you guys running to help to keep the cams idleing?
Old Nov 20, 2005 | 05:18 PM
MalibuJack's Avatar
There is a setting in the UTEC that you can use to alter fueling when the coolant temp is above a certain point, used typically for hot days to back off timing and add fuel, but you can use it for cold start until coolant temp goes above a certain point since its not really used by default.
Old Nov 21, 2005 | 09:06 AM
what throttle possition should I start tunning for meth?
Evo_Goodness
Aug 30, 2016 04:00 AM
ant_turbo
Jun 5, 2016 06:08 PM
quentinpy
Oct 12, 2015 05:54 AM
MrJoshH
May 25, 2015 11:21 AM
edison
Northwest Region
13
Oct 10, 2009 03:26 PM
