MAFTP with reflash
Old Nov 21, 2005 | 07:31 PM
PeteyTurbo's Avatar
MAFTP with reflash
If I were to install the maftp, would it be advisable to flash my car back to its stock configuration?
Old Nov 21, 2005 | 07:42 PM
joeymia's Avatar
If you flash back to stock you will probally run into fuel and boost cuts. MAFTpro will work fine over a flash.
Old Nov 21, 2005 | 07:49 PM
dryad001's Avatar
Hmm. I thought that the maftpro will eliminate the fuel cut? "Maximum MAF HZ" this is what I set a little higher, I haven't run into boost or fuel cut yet running 22 psi.
Old Nov 21, 2005 | 07:52 PM
joeymia's Avatar
I am pretty sure its still there. I hit fuel cut on the way up to Orlando to have Jestr tune my ECU.
Old Nov 21, 2005 | 08:02 PM
dryad001's Avatar
Thats odd.
Old Nov 21, 2005 | 10:00 PM
PeteyTurbo's Avatar
So instead of modifying from the factory trims, I will be manipulating the values incorperated into the reflash from 0% on the translator correct? Wouldn't that throw things off if I added larger injectors? I do understand some of the boost cut ect. limits have been raised with the reflash, I just want a solid table to work from.
Old Nov 22, 2005 | 02:12 PM
TTP Engineering's Avatar
No there is a mainscale adjustment that will shift the whole fueling map over to normal once the correct "lean shift" is entered. 20% larger injectors? Mainscale set to -20%.
Old Nov 22, 2005 | 02:34 PM
dryad001's Avatar
I run 780's and that is about 30% larger, I have the main scale now at -26% and seems to run pretty good, but at idle I have to add about 14% fuel.
Old Nov 22, 2005 | 02:39 PM
Make sure your afterstart enrichment setting is correct. This creates a large driveability issue if left lean.
