Knock Setting
Old Dec 2, 2005 | 04:49 PM
dsevo's Avatar
Knock Setting
I have a quick question regarding the knock setting on ECU+. Should I have it set at Peak-Hold w/ Decay, or Instantaneous? I had it at Peak- Hold w/Decay since I got the ECU+, but it seems to read high, even at stock settings. I tried instantaneous today and it seemed a lot more realistic, but hey, what do I know. I need to know this before I start playing with timing, because I don't want to be looking at the wrong knock readings.
Also, I have my fuel tuned for 11:1 from 5250 rpm and up, does that sound ok on California 91? Thanks
Old Dec 2, 2005 | 04:50 PM
vboy425's Avatar
hell no, not on cali piest gas. have it like 10.5-10.8
Old Dec 3, 2005 | 10:02 AM
dsevo's Avatar
I'll add a little more fuel. My egt's are about 850c which is pretty good, but I'll still add a little fuel. Thanks.
Old Dec 19, 2005 | 02:46 PM
RazorLab's Avatar
what knock voltage spikes are you getting?
Tom says to leave it at peak hold with decay for accurate knock events. You really have to watch your knock volts on cali 91 octane, just because your AFR seems to be at a safe number, it doesn't mean it's safe.
Old Dec 19, 2005 | 02:53 PM
Ev0ikon's Avatar
+1 on Peak-Hold/Decay.
Old Dec 20, 2005 | 07:48 PM
dsevo's Avatar
Is it pretty much unanimous that ecu+ users set their knock threshold to 2.5v? Is that a pretty safe number, because I am really relying on that with my tuning? Thanks
Old Jan 8, 2006 | 11:55 AM
fre's Avatar
fre
Hrmmm 11:1 sounds rich. I run about 11.5:1 on 91 and 19psi.
As far as knock goes, I use AEM, but my threshold is about 2.8V. BTW A/F won't effect your knock nearly as much as your timing will. This means throwing fuel at a map with too much timing proabably isn't going to fix your problem.
Old Jan 16, 2006 | 06:59 AM
honki24's Avatar
I use 2.23 volts... but I havent pushed it yet.
Old Feb 26, 2006 | 09:41 AM
SSKILLA's Avatar
2.75 here......and hes right 11.2 till about 11.6afr sounds about right just watch that knock and keep timing down dont get too crazy
i have big cams though so my knock spikes up here and there but its not really knocking or pulling timing
