Tuning for cams
Old Dec 20, 2005 | 05:43 PM
S2Kstephen's Avatar
Tuning for cams
AMST is having a cams Xmas special, and I'm sersiously thinking for getting the HKS 280 with AEM cams gear setup.
Right now, I have a mail-in Dynoflash, and I'm wondering if:
1) I should send it back for another flash, including the newly installed cams
2) Take the hike up to TurboTrix and get a real dyno tune. Whats the cost?
3) Do I need a SAFC in order to get a proper tune?
Thanks for your help!
-Stephen
Old Dec 21, 2005 | 06:01 AM
TurbotrixRacing's Avatar
-Stephen
stephen .
you dont need an afc for a proper tune. And your probably losing about 20whp without a custom tune. So if it makes sense then just get the mail in .. BTW we do mail in's as well
mark
turbotrix
Old Dec 21, 2005 | 06:29 AM
walkedu's Avatar
Mail it in man! Make sure you sqeeze all dem ponnies out those cams will give ya!
Old Dec 21, 2005 | 06:33 AM
Cali2MDevo8's Avatar
Registered User
If your getting cams/cam gears installed, you want a custom tune. Extract all the possible hp/tq as possible w/ a custom tune.
Old Jan 10, 2006 | 01:20 PM
mike1023's Avatar
with the hks 280 do you need other things for the head like springs or vavles.
Old Jan 10, 2006 | 08:50 PM
spoolinspyder's Avatar
I'd put stiffer springs in myself only because if your pumping a large turbo in the higher rpms, valve float can be an issue. stiffer springs and a lighter valve train will definitely help out.
