CEL Problem
Old Dec 21, 2005 | 05:58 AM
dvsevo8's Avatar
CEL Problem
Any of you guys ever had this code pop up?
P0507 High RPM
Old Dec 21, 2005 | 06:30 AM
walkedu's Avatar
P0507 Idle Control System RPM Higher Than Expected. What were you doing when you got this?
Old Dec 21, 2005 | 07:52 AM
dvsevo8's Avatar
jus got it for the last few weeks... since the cold weather started here in nyc. i had the code checked by several diff mechanics and all said they are not sure wut it is.
my driving habits have been the same. its daily driven on the streets of nyc. i do get the occasional urge to punch it ... but the car is never reved above 6500 rpm
any helps or tips would be appreciated...
Old Dec 21, 2005 | 02:44 PM
RallySport Direct's Avatar
Silver Sponsor
The code is saying your idle is higher then it should be. It is most likely related to your mods. Maybe Cams? Anyone mess with the idle screw to make it idle better? Stuff like that could cause this code.
Ben
Old Dec 22, 2005 | 11:18 AM
dvsevo8's Avatar
yes... i have 264/272 cams with the flash...
i will check the idle screw and post udates...
thankz guyz
