View Poll Results: Do you want a SAFC-2 Plug and Play Harness for your IX
Voters: 51. You may not vote on this poll
Petition for Boomslang to make SAFC-2 Plug and Play Harness for IX
PLEASE SPECIFY TYPE OF EVO IX HARNESS:
STRAIGHT ECU EXTENSION ONLY: $159
1. Czubaka
2.
3.
4.
5.
ECU EXTENSION FOR SAFCII: $199
1. Lancer EVO IX
2.
3.
4.
5.
ECU EXTENSION FOR APEXi NEO (NEW SAFC): $199
1. Shadowist
2.
3.
4.
5.
ECU EXTENSION FOR ZEITRONIX WIDEBAND OR MAFTPRO! $179
1.
2.
3.
4.
5.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
1.
2.
3.
4.
5.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
1. Evo_kid (Zeitronix)
2.
3.
4.
5.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
2.
3.
4.
5.
Everyone enjoy your new harness. With the release of ECUFlash compatable cables to monitor and modify your own ecu flash, I don't see the point in getting an ecu extesion; a straight-thru anyways.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
2.
3.
4.
5.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
2.
3.
4.
5.
My payment will be sent on Monday, just to let everyone know.
TTP, why does it only work if everyone pays, is it a group buy???
I though you started stocking them and that why their available now.
Even though we do have "the cable" and EVOScan, evoscan still cant implicate a WB yet, so that mean we still have to hook up WBs.
I have my plx wb unit tapped into 4 measily wires on the harness. Hardly warrants spending $100+. Plus since it's the R-500, I can log up to 99 min as well or stream the data in real time through usb2.
If you had the zeitronix wideband you would have more taps. Then again you would be logging much more. You can log 540 minutes of data with the zeitronix.
Scott - Just so I understand this, the zxietonix harness is a harness extension that also has specific wires tapped in for a zietronix, but could also be used for a SAFC or gauges etc? I can pay ASAP. Thanks!
I added my name below!
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
2.EvoIXMR (Zietronix)
3.
4.
5.
1. Czubaka
2.
3.
4.
5.
1. Lancer EVO IX
2.
3.
4.
5.
1. Shadowist
2.
3.
4.
5.
3.
4.
5.
Or you can go with the standard zeitronix plug and manually tap the safc wires at a later date. They are different prices which is why I point this out.
Originally Posted by TTP Engineering
Yes, make sure though if you intend to buy a SAFC that you get the correct harness though. Typically if you bought one for the zeitronix, then the SAFC plug would not be on there premade. If you have the safc and intend to use it now, I would buy the one with the SAFC plug and we can ADD the zeitronix plug to it.
