can the safc2 control the fuel rich or not?
Old Jan 16, 2006 | 12:55 AM
lazyfishkim's Avatar
Unhappy can the safc2 control the fuel rich or not?
i'm tryin to get my evo fuel runs more rich...so..i'm wondering if i can do it with my safc2...because..i don't know...i'm just very into the flame things... special after reading this thread..
https://www.evolutionm.net/forums/showthread.php?t=44205&highlight=exhaust+flame ....
i'm running with...HKS downpipe... straight pipe...hks hi power...280 hks cams..cam gears... hks intake....greddy e-01 boost control.... safc 2... but i never been allow to do the flame with gun shot sound.... just saw one today.... IT'S EVEN JUST A STOCK RX8.....DAMN IT......what can i do?
Old Jan 16, 2006 | 01:09 AM
Enyth's Avatar
so you just want the rice flamer?
Old Jan 16, 2006 | 10:14 AM
i just wish to run the fuel rich....so i can be able to rice flame and the gun shot sound.....it is possible with safc2? set to let the fuel run rich!??
Old Jan 16, 2006 | 10:19 AM
matt55's Avatar
I hope no one helps you on this , this is sad
Old Jan 16, 2006 | 10:22 AM
BaseModelEvo's Avatar
Nice Mods...now going rice huh?
Old Jan 16, 2006 | 10:56 AM
evo8rcr's Avatar
thats souns very bad for the car and I know it's not legal plan on some fix it tickets
Old Jan 16, 2006 | 11:00 AM
taenaive's Avatar
you can run rich with SFAC with stock injectors but it will pull a lot of timing plus you will get fuel cut. I suggest get bigger injectors and control with SAFC. try that with 880cc. you will run so rich, you can't even idle well.
Old Jan 16, 2006 | 03:34 PM
levo2nr's Avatar
wow i cant believe i am reading this ...
but ok
good luck with ur flames
Old Jan 17, 2006 | 07:10 PM
ddubb's Avatar
wow...ok, so if all you want are the flames here is how you do it....sell all of your mods that you currently have installed b/c none of them will help you with this. Go out and get a flame kit that anyother kid with a civic might have. there you go, seriously though, you're joking right,there is no way anyone buys a safc2 to make flames.....right?
Old Jan 20, 2006 | 06:48 AM
TTP Engineering's Avatar
Fouled plugs
Cylinder wash and possible piston ring damage
Oil contamination
P0300 misfire code
P0172 cylinder too rich bank 1 code
Fouled O2 sensors @ $250 ea
Advanced fuel cut
Low timing
Loss of 25-30whp
Gas mileage cut +/- 30%
Laughing stock of evolutionm.net = Priceless
