Log Time - Tune Tomorrow, Opinions wanted.
Old Mar 3, 2006 | 04:45 PM
WarmPepsi's Avatar
My thoughts:
could use a little fuel on spoolup, but the rest of it, for a street-fuel map seems good, we'll see tomorrow on the dyno.
Code:
2725,-10.2, 303, 35, 10,   00,  32.1,  +26.6,  11.9,ECU. , +5.0,ECU.  , 256
 2768, -8.7, 353, 45, 10,   00,  14.8,  +24.5,  13.3,ECU. , +5.0,ECU.  , 280
 2810, -6.6, 395, 60, 10,   00,  13.6,  +21.5,  15.0,ECU. , +5.0,ECU.  , 330
 2866, -4.1, 440, 76, 10,   00,  12.7,  +19.6,  16.5,ECU. , +5.0,ECU.  , 357
 2903, -1.7, 463, 91, 10,   00,  12.2,  +17.5,  18.2,ECU. , +5.0,ECU.  , 328
 2986, +0.7, 558,100, 10,   00,  12.1,  +15.0,  20.6,ECU. , +5.0,ECU.  , 480
 3049, +3.1, 600,100, 10,   00,  11.9,  +12.3,  23.4,ECU. , +5.0,ECU.  , 518
 3095, +5.5, 694,100, 10,   00,  11.9,   +9.1,  26.3,ECU. , +5.0,ECU.  , 424
 3183, +7.7, 758,100, 10,   00,  11.7,   +7.7,  28.6,ECU. , +5.0,ECU.  , 661
 3271,+10.1, 844,100, 10,   00,  11.7,   +5.2,  30.9,ECU. , +5.0,ECU.  , 702
 3367,+12.8, 871,100, 20,   00,  11.7,   +5.2,  32.2,ECU. , +5.0,ECU.  , 560
 3472,+15.2, 894,100, 20,   00,  12.0,   +6.7,  33.0,ECU. , +5.0,ECU.  , 720
 3576,+17.6, 891,100, 30,   00,  12.3,   +5.4,  33.2, +8.3, +8.0,ECU.  , 673
 3671,+19.1, 950,100, 30,   00,  12.0,   +3.6,  35.4, +8.5, +8.0,ECU.  , 925
 3787,+20.1,1008,100, 30,   00,  12.0,   +4.1,  40.4, +8.6, +8.0,ECU.  , 548
 3862,+20.5, 990,100, 30,   00,  11.1,   +4.1,  43.8, +9.2, +8.0,ECU.  ,1000
 3944,+20.5,1072,100, 40,   00,  11.0,   +4.1,  43.1, +8.1, +8.0,ECU.  , 909
 4070,+20.5,1026,100, 40,   00,  11.1,   +4.0,  42.8, +8.5, +4.8,ECU.  ,1008
 4192,+20.5,1091,100, 40,   00,  10.8,   +4.0,  44.4, +8.8, +2.4,ECU.  , 659
 4290,+20.5,1101,100, 40,   00,  11.3,   +6.9,  43.7, +9.2, +0.0,ECU.  , 902
 4385,+20.5,1101,100, 40,   00,  11.5,   +8.4,  43.8, +9.0, +0.0,ECU.  , 670
 4438,+20.5,1187,100, 50,   00,  11.7,   +7.2,  46.4, +7.2, +0.0,ECU.  , 915
 4559,+20.5,1196,100, 50,   00,  11.5,   +8.2,  47.6, +7.0, -0.9,ECU.  , 718
 4681,+20.8,1216,100, 50,   00,  11.5,   +8.4,  47.3, +7.1, -1.8,ECU.  , 892
 4734,+20.8,1228,100, 50,   00,  11.4,   +8.7,  48.1, +7.1, -2.1,ECU.  , 909
 4844,+20.8,1285,100, 50,   00,  11.6,   +8.9,  48.9, +7.3, -2.6,ECU.  , 992
 4938,+21.0,1315,100, 60,   00,  11.4,   +7.8,  50.6, +7.4, -2.3,ECU.  , 791
 5035,+21.0,1315,100, 60,   00,  11.3,   +8.9,  51.2, +7.5, -2.0,ECU.  , 992
 5128,+21.0,1355,100, 60,   00,  11.5,   +8.3,  52.7, +7.8, -2.0,ECU.  ,1008
 5232,+21.0,1400,100, 60,   00,  11.4,   +8.3,  52.8, +8.1, -2.0,ECU.  ,1101
 5316,+21.0,1392,100, 70,   00,  11.4,   +9.4,  53.6, +7.9, -2.0,ECU.  , 965
 5393,+21.0,1424,100, 70,   00,  11.4,   +9.5,  54.3, +7.9, -2.0,ECU.  ,1141
 5500,+21.3,1436,100, 70,   00,  11.4,   +9.9,  55.2, +8.0, -2.0,ECU.  , 996
 5583,+21.3,1461,100, 70,   00,  11.3,   +9.7,  55.5, +8.6, -2.0,ECU.  ,1152
 5659,+21.3,1492,100, 70,   00,  11.3,  +10.9,  57.6, +9.2, -2.0,ECU.  ,1101
 5747,+21.3,1488,100, 80,   00,  11.3,  +12.1,  58.2, +9.6, -2.0,ECU.  ,1196
 5837,+21.0,1533,100, 80,   00,  11.4,  +13.3,  60.4,+10.2, -2.0,ECU.  ,1020
 5941,+21.0,1497,100, 80,   00,  11.3,  +14.4,  60.7,+10.9, -2.0,ECU.  ,1101
 5995,+20.8,1524,100, 80,   00,  11.1,  +14.4,  61.2,+11.4, -2.0,ECU.  ,1146
 6116,+20.8,1552,100, 80,   00,  11.1,  +15.2,  63.3,+11.8, -2.0,ECU.  ,1091
 6172,+20.8,1582,100, 80,   00,  11.0,  +15.5,  63.9,+12.3, -2.0,ECU.  ,1213
 6242,+20.8,1582,100, 80,   00,  11.0,  +16.6,  64.7,+13.0, -2.0,ECU.  ,1243
 6349,+20.8,1582,100, 80,   00,  11.1,  +17.6,  65.1,+13.4, -2.0,ECU.  ,1269
 6397,+20.8,1612,100, 90,   00,  11.1,  +17.8,  66.6,+11.3, -2.0,ECU.  ,1243
 6472,+20.8,1644,100, 90,   00,  11.0,  +19.2,  66.1,+11.7, -2.0,ECU.  ,1231
 6535,+20.8,1666,100, 90,   00,  11.2,  +19.3,  66.9,+12.0, -2.0,ECU.  ,1162
 6600,+20.8,1633,100, 90,   00,  11.2,  +20.3,  66.7,+12.3, -2.0,ECU.  ,1196
 6693,+21.0,1644,100, 90,   00,  11.2,  +20.4,  67.0,+12.7, -2.0,ECU.  ,1173
 6747,+21.0,1677,100, 90,   00,  11.2,  +22.6,  67.0,+12.8, -1.6,ECU.  ,1225
 6802,+21.0,1683,100, 90,   00,  11.3,  +21.8,  68.5,+13.1, -1.9,ECU.  ,1295
 6858,+21.0,1694,100, 90,   00,  11.2,  +23.5,  68.6,+13.3, -1.8,ECU.  ,1275
 6930,+21.0,1683,100, 90,   00,  11.2,  +23.6,  68.7,+13.7, -1.7,ECU.  ,1213
 6944,+21.3,1712,100, 90,   00,  11.1,  +25.5,  68.1,+13.9, -1.5,ECU.  ,1250
 7032,+21.3,1694,100, 90,   00,  11.1,  +25.7,  68.1,+14.1, -1.5,ECU.  ,1237
 7092,+21.3,1700,100, 90,   00,  11.2,  +25.6,  69.9,+14.5, -1.5,ECU.  ,1256
 7153,+21.0,1689,100, 90,   00,  11.2,  +25.8,  69.3,+15.2, -1.5,ECU.  ,1173
 7199,+21.0,1712,100,100,   00,  11.0,  +25.6,  69.3,+16.4, -1.5,ECU.  ,1322
 7246,+20.8,1700,100,100,   00,  11.2,  +25.8,  69.7,+16.5, -1.5,ECU.  ,1237
 7309,+20.8,1683,100,100,   00,  11.1,  +25.6,  68.7,+16.7, -1.7,ECU.  ,1237
 7374,+20.8,1742,100,100,   00,  11.2,  +26.0,  69.2,+16.7, -1.9,ECU.  ,1269
 7407,+20.8,1712,100,100,   00,  11.2,  +25.7,  69.0,+16.9, -2.1,ECU.  ,1213
 7440,+20.8,1724,100,100,   00,  11.2,  +26.9,  70.0,+17.1, -2.2,ECU.  ,1196
 7490,+20.8,1694,100,100,   00,  11.3,  +26.9,  68.9,+17.3, -2.5,ECU.  ,1329
 7541,+20.8,1689,100,100,   00,  11.2,  +26.7,  69.2,+17.5, -2.5,ECU.  ,1269
 7593,+20.8,1694,100,100,   00,  11.2,  +26.8,  68.9,+17.5, -2.5,ECU.  ,1275
 7627,+20.8,1712,100,100,   00,  11.1,  +26.8,  68.9,+17.6, -2.5,ECU.  ,1275
 7662,+20.8,1700,100,100,   00,  11.3,  +27.0,  69.2,+17.7, -2.5,ECU.  ,1237
 7733,+20.8,1742,100,100,   00,  11.2,  +27.0,  69.2,+18.0, -2.5,ECU.  ,1282
 7751,+20.8,1718,100,100,   00,  11.2,  +28.0,  69.5,+18.4, -2.6,ECU.  ,1162
 7627,+20.8,1483,100,100,   00,  14.3,  +29.0,  65.9,+18.0, -2.5,ECU.  ,1231
Old Mar 5, 2006 | 03:10 AM
WarmPepsi's Avatar
thx guys
Old Mar 5, 2006 | 09:54 AM
EVO8LTW's Avatar
so what happened on the dyno?
That sure looks like a lot of timing up top. Was this a race gas or alky tune?
Old Mar 5, 2006 | 10:08 AM
WarmPepsi's Avatar
that was all the timing based off the stock map, went in with no knock at all, pulled a first run of 286, with it pulling timing up top, flatted out the a/f, ended up right at 300, then pulled a good amount of timing up top, and actually lost a few hp. no worries for me though, it's a reasonably safe road tune now..
next time sean is through, i'll let him have fun with it.
My maps weren't calling for anywhere near that much timing up top, was kinda baffling to me honestly. I de-tuned it to where i felt comfortable, which was a good deal, (also due to lack of airflow in the dyno room, 2 fans just can't keep up.)
Old Mar 7, 2006 | 03:13 PM
Widebandphillip's Avatar
What are your mods? You can definately put more timing in for torque if you wanted. I also think that there is a lot of timing up top but if the motor likes it, no problem. Fuel looks nice.
Old Mar 7, 2006 | 03:17 PM
WarmPepsi's Avatar
all bolt-ons, 3" turbo back, test pipe, injen fmic/pipes/intake, hks 272's (-4,-1)
See, the timing is kinda bothering me, i wasn't calling for anywhere near that timing, but yet, it was running it. I pulled a lot out for a safer road tune on the dyno, but saved the old map, because i really wasn't getting any knock at all.
My map says i'm calling for a max of +20 at any given point, any reason it'd be adding it on it's own?
Old Mar 7, 2006 | 03:54 PM
oh wow..nvm my comments, i was looking at the wrong column. You're utec timing is fine. My only suggestion would to move the peak torque timing down to about 3700 or so beceause the way you have it now, you're saying peak torque is above 4k and it shouldn't be. The ecu timing is probably adding on it's own since you have bigger injectors.
Old Mar 7, 2006 | 05:01 PM
WarmPepsi's Avatar
any chance you could elaborate, or point me to some more info on your last sentance?
This map was roughly based off the base map, timing has only been pulled, never added, so it's about as watered down as can be, yet, i was getting a few instances of knock up top(before i posted this whole chart) and therefore, backed the timing down some more.
The unwanted adding is kinda a nuisance, but i'm not 100% sure yet.
Old Mar 13, 2006 | 10:57 PM
With bigger injectors, usually people take more fuel away from the ecu which tricks the ecu into throwing more timing at the motor. That's why the ecu timing is going high, and this is why safcs work =).
Old Mar 14, 2006 | 05:10 AM
WarmPepsi's Avatar
ahh, i see.
Now my question is i set my injector size for 680, and tuned accordingly, and it works fine, should i have set it at 750 (which they are?)
When i set it to 750 it was SUPER rough, and didn't wanna run, 680 setting ran, but i still added fuel under 1500.
Would setting it different make any change through utec?
Old Mar 14, 2006 | 02:25 PM
The injector scaling feature in the UTEC uses an arbitrary number. Even though you have 750's , putting 750 into the utec isn't really the way to do it. It's a number you'd have to find out, it could be 300 or it could be 600 (just throwing some numbers out there). What i'd recommend doing is just set the injector size back to stock 550 and 550. I'd do all the scaling through the utec fuel map by starting off with -10 across the whole board.
Old Mar 15, 2006 | 04:29 AM
WarmPepsi's Avatar
Well, i mean, other than adding timing, which i pulled it back a little, it runs good.
And for now, it's moderatly tuned that way, may adjust later though. Thanks for the input.
