Intake, Turbo-Back, and IC = Fuel Cut????
Originally Posted by evohang
ey how much is for that FUEL CUT DEFENDER???? because my car is having the same problem and i dont want to spend to much on my vehicle since i already did. I have a boost gauge to be installed so i might go with the MANUEL BOOST CONTROLLER since its cheaper than the EBC just so i can fix that problem. Im not trying to make my car JET fast but i just want to have my car running good and still be fast.
However you really should get a flash because you will get many other benefits then just fixing your problem. And dude lets not beat around the bushes YOU CAN NEVER HAVE ENOUGH POWER!!!
will i gain HP with the flash???...how long does it take for it to be flashed??...includeing the days its being shipped in and out???....is it hard to take your ecu out?....yes i know very easy questions for you guys to answer but then for me im a newbie dont know much so if i could get as much help as i can it would be really appreciated instead of hatin' on us newbies! thanks!
Yes, you are guaranteed by Dynoflash a minimum of 20hp. 3 days total. One day shipping each way and one day for the flash. Very easy to take out the ECU- there is a thread in the how-to section.
Originally Posted by ix_wagone
evohang I just found that HKS also make one, check out this link http://www.overboost.com/obs/product.asp?pid=28883
WILL SOON GET THAT FLASH!!!!!!!!!!!
To answer your original question, your car's making too much boost and that's why you're hitting a fuel cut. With the new exhaust, you have much less backpressure and therefore the car can take in more air and therefore it can make more boost than the ECU thinks is safe.
You're hitting the fuel cut because SOMETHING BAD is happening to your car (too much boost), and the fuel cut is your car's way of NOT BLOWING UP. You don't want to keep driving hard without a boost controller to lower the boost.
You'd be able to verify this if you had a boost gauge. You might be hitting boost spikes of 23+ psi.
Also, the issue here isn't "removing the fuel cut," as you've put it several times. The issue is running a safe amount of boost, and that's why a boost controller is immediately necessary. If you're going to continue to use the intake, then a tune will help as well. You also need a fuel pump if you're going to get tuned, especially with an intake.
More info on your fuel cut:
https://www.evolutionm.net/forums/sh...6&page=1&pp=15
MattevoVIII
25
Feb 18, 2007 05:25 PM
Srt-4 Turbo 7
13
Feb 15, 2007 10:54 PM
Chris@nolimitmotors
16
Nov 28, 2004 08:06 PM
