Datalogit W/out the waite
beta 2 of the datalogit software is avaiable on the yahoo groups.
they've released a generic fc edit to suit all powerfcs (to match the type b cable).
some minor bugfixes.
I've uploaded the first (beta) release of universal FC-Edit
software. Functionality should be the same as the seperate FC-Edit
versions. All FC-Box types will work with the software - but if the
box type (A or B) does not match the Power-FC, then you may
get "Interface not responding."
Most of the work was behind the scenes, but there's also a couple of
minor additions:
- Airflow table has a tracer option, (right click to access) which
should allow easier tuning of the airflow curve.
- Drag and drop .dat files onto FC-Edit.
- Com port menu only shows available ports
For now I have disabled the Compare feature, due to the
complications of comparing different Power-FC versions.
Of course I have thoroughly tested on my RX7 Power-FC, but now I
need your help testing on other Power-FC's. Of course please be
advised that this is Beta software. There may be bugs. If you are
not comfortable with this possibility - then do not use it, wait a
while until it is officially released.
Once testing and bug fixs are done - then I can work on adding new
features. So if you do want new features - help me out by giving it
a try, and report any problems to me.
Thanks in advance
Steve
FC-Datalogit
minor additions:
Thanks in advance
Steve
FC-Datalogit
