Intake air temp sensor and methanol?
Old Mar 24, 2006 | 08:44 AM
pjsevo8's Avatar
Question Intake air temp sensor and methanol?
I was wondering where to tap my intake air temp sensor if I am running pure methanol. I wouldnt want it to spray and ruin the readings of the sensor. If anyone could help me with this that would be appreciated.
thanx
PJ
Old Mar 24, 2006 | 08:56 AM
johnjonfenomeno's Avatar
I taped mine before the sensor... You don't wanna spray meth on that to offset the readings. Mine ait is tapped midway on the uicp
Old Mar 24, 2006 | 09:37 AM
pjsevo8's Avatar
and that has worked fine for you so far?
Old Mar 24, 2006 | 10:12 AM
yes absolutely
Old Mar 24, 2006 | 10:55 AM
pjsevo8's Avatar
ok thank you very much!!! i just need to find a iat sensor to put in and the right size to tap it in.
PJ
Old Mar 24, 2006 | 11:00 AM
Cajun Power's Avatar
On the stock IC pipes I would use the verticle hard pipe. The one that is right behind the drivers headlight. Your Methanol nozzle should be on the next pipe. The one between the battery and the cam cover. Your air temps would be accurate and you wouldn't have to worry about the meth hitting the sensor. It can be a bit corrosive. Anything after the IC should give you a good reading.
Old Mar 24, 2006 | 11:09 AM
pjsevo8's Avatar
ok thanx!
Old Apr 19, 2006 | 10:22 AM
speedjunkie2003's Avatar
yea i agree tap it before the sensor, good luck :P
Old Apr 19, 2006 | 10:24 AM
pjsevo8's Avatar
Yea i got a bung welded on the upper pipe after the ic and it works out great so far thanx for the help guys!
PJ
esevo
43
May 31, 2015 05:55 AM
PERRIN_JOHN
Nov 27, 2009 10:38 AM
EvO6-RS2
17
Jul 12, 2006 07:08 PM
ct9a gsr
27
Mar 21, 2006 03:49 PM
TrinaBabe
35
Dec 11, 2005 09:25 PM
