OBD Scanning??
Old Apr 4, 2006 | 07:29 AM
Creamo3's Avatar
OBD Scanning??
Just installed the ECU+ and it is able to log all vital info, but I am not able to see any info when I pull up OBD Tab. I had a CEL light come on yesterday and it didn't register and I was still able to clear the code via the old OBDII port w/ my old code scanner. Any ideas as to what I may be doing wrong? I was under the impression that I wouldn't be able to use the OBD port and do everything via ECU+.
Old Apr 4, 2006 | 07:40 AM
Ev0ikon's Avatar
I bet you forgot to set the jumper inside the silver box
Old Apr 4, 2006 | 10:35 AM
Creamo3's Avatar
I bought the box used, I will have to go through the manual to see if I can figure this out, can't you also just cut a wire if I remember correctly if you want to use your old OBD port?
Old Apr 4, 2006 | 11:05 AM
Ev0ikon's Avatar
Thumbs up
Do not cut any cable. There is a jumper that you have to set inside the box. The box is easy to open. Read the manual about it. Shouldn't take you more than 5 min to have that done
Old Apr 4, 2006 | 12:12 PM
Creamo3's Avatar
Thanks
Old Apr 4, 2006 | 07:03 PM
tlcoll1's Avatar
E-mail me for the procedure.
Tom
Old Apr 4, 2006 | 07:11 PM
Creamo3's Avatar
Tom
you have mail I sent it support@ecuplus.com is that your email?
